May 18, 2023 at 11:23 am
Carlos
SubscriberHi,
I have defined an array of 3x3 elements. In each of them I have defined a port with 2 excitation modes. The problem is that when analysing the modes, each port applies a different polarisation, as shown in the images. How can I make all the cells have the same polarisation, as shown in the first image?
Thanks.Â
May 18, 2023 at 1:19 pm
Chinmay T
Forum ModeratorHello,
How did you assign the wave ports?
Please share the screenshots of mode alignments (you can get it by clicking on the wave ports under excitations node in the Project manager wnido) for all the wave ports and edit sources dialogue box.
Thanks!
Chinmay-
May 19, 2023 at 1:13 pm
Carlos
SubscriberDo you know how can I do it?
Thanks again!
May 18, 2023 at 1:28 pm
Carlos
SubscriberI have defined the integration line in such a way that both modes are orthogonal. However, I have tried different configurations such as putting only the integration line to the first mode, and the second one undefined, or the second one with the same line as the first mode.ÂIn addition, from the Edit Sources window, I also tried changing the phase of the second mode, but this had no effect either.ÂI attach the images.ÂÂÂÂKind regards. -
May 22, 2023 at 8:44 am
Chinmay T
Can you please share the screenshots of all the field patterns belonging to the modes from Port Field Display?
Thank you,
Chinmay-
May 22, 2023 at 9:48 am
Carlos
May 22, 2023 at 12:44 pm
Chinmay T
We need more information about your model.
What kind/type of array you are simulating?
Kindly share the setup of your model, boundary conditions, materials, etc. that you used to simulate this model.
Thank you,
Chinmay-
May 22, 2023 at 2:54 pm
May 26, 2023 at 6:33 am
Chinmay T
Forum ModeratorHello Carlos,
I meant, what type of application you are simulating? Is it transmission line, waveguide or some other application?
Thanks,
Chinmay-
May 26, 2023 at 6:58 am
Carlos
SubscriberIn this case it is a waveguideÂ
May 30, 2023 at 12:16 pm
Chinmay T
Forum ModeratorÂ
Please try increasing the length of the waveguide and instead of radiation boundary assign the ports to the other end of the waveguides and check.
You can go through the "Waveguide Simulation Using Ansys HFSS" AIC course for more information on how to simulate waveguide using Ansys HFSS.
Thank you,
ChinmayÂ
- The topic ‘Polarisation mode in different port for arrays’ is closed to new replies.
6625
1311
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
.png)
