Plotting Von Misses Stress X Distance or Coordinate Node or Element
    • Fabricio.Urquhart
      I would like to plot a graph with the edge von misses stress, like the picutre below. But in place of time, I would like to plot the X coordinate along the edge. So the results will be a line per time like the second picture. Is there any command in apdl that do it??
      Fabricio,
      In Mechanical, you use Construction Geometry to create a Path to plot stress along that path.  Here is the SimuTech group tutorial.
      Peter
    • Rohith Patchigolla
      Hello Fabricio,
      As Peter suggested, you can get distance along the edge vs stress plot using Construction Geometry (Path).
      If you want to have X-coordinate (and not distance along the edge) vs stress plot instead, you can create in the following way.
      1. Create a Equivalent stress result along a path as Peter suggested
      2. Create a User defined result along a path, with expression LOCX
      3. Highlight both objects created above and create a Chart
      4. In the created chart, change the X axis (under Chart Controls) from "Length" to this "User defined result" created in step 2 to get  X-coordinate vs stress plot
      You can also combine multiple Equivalent stress results (at multiple time points) into one chart.
      Hope this helps.
      Best regards,
      Rohith
    • Fabricio.Urquhart
      Thank you!
      To create a path, it is necessary to create a edge in the geometry. If you do not have the edge, the results do not recognize the path.
      Fabricio,
      I see from your snapshot that edges are present (circled in red). Let me know if I am missing something?
      Best regards,
      Rohith
    • Natalia
      Hi all!
      I am sorry for not opening a new thread (neither uploading a pic) but for some reason it is impossible since a few days ("Sorry an error occured"). Could you please help me to plot a stress in a function of edge length along a non-linear 2D edge? I need it to compare several simulation with different loads. I am guessing that I might need to get all the values on the nodes with the apdl commands but I don't want to search blindly. Could you please give me any hint?
Viewing 5 reply threads
  • The topic ‘Plotting Von Misses Stress X Distance or Coordinate Node or Element’ is closed to new replies.
