January 17, 2020 at 11:25 am
stranalyst
SubscriberHi,
I couldn't find out how to plot surface pressure distribution during post processing on Ansys mechanical? I can see temp. distribution using BFE with user defined results. Anyway to see pressure distribution??Â
January 19, 2020 at 12:15 pm
peteroznewman
SubscriberIf you have Frictional or Frictionless or Rough Contact, then you can insert a Contact Tool into the Results and then Insert a Pressure plot into the Contact Tool.
January 19, 2020 at 4:15 pm
stranalyst
SubscriberHi Peter,
I actually asked for the surface pressure that we mapped on a surface before the analysis. With BFE, for example, we can probe the temperature which we mapped on a body on various locations, during post-processing. Can we do the same for surface pressure?
October 2, 2023 at 5:57 pm
jkaempfer
SubscriberI am also interested in a solution for this. Is there really no way to visuallize the applied pressure boundary condtions?
- The topic ‘Plotting surface pressure’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4507
1494
1386
1209
