Plotting force Vs time on fluent
    • Vishnuraja
      Hi guys I am presently working on fluent for solving multiphase flow over cylinder.
      For the problem I need to plot vertical force Vs time .I could actually see the vertical force from reports.but wat I need is to plot the vertical force Vs time...It will be greatful if anyone help me out of this.
      Thank you
    • Vishnuraja
      This is so important..if anyone could help me..pls.
      You need a monitor, and then plot that as the model runs.
      As an aside, bumping a post on the day it's added isn't going to speed anything up. After a few days it's fair enough as we may have missed it.
    • Vishnuraja
      Thanks for the rply
      Actually what I need is force Vs flow time .I didnt get it what you meant by monitoring .could we actaully monitor force Vs flow time..or is it lift coeff..
      I don't need to plot lift coeff..if monitoring force is possible could you pls elaborate..
    • Amine Ben Hadj Ali
      You go to report definition and create a force monitor. Check some tutorials which explain it.
    • Vishnuraja
      Thanks for the reply.
      Actually I was using ansys 16.1 and there is no such report definition option in it.
      I tried monitors , but there is no force monitor in it . I was able to monitor lift coefficient but for my problem velocity keeps changing so I need to plot force itself.
      Then the old force monitor plot. Try updating to an actual release
    • Vishnuraja
      Hi..
      I dnt understand what u meant. It will be helpful if elaborate.
      Actually there is no force monitor in monitor..Lift coeff and drag coeff are available .but I need to plot vertical force
      Check https://confluence.cornell.edu/display/SIMULATION/Flow+over+an+Airfoil+-+Numerical+Results
    • Vishnuraja
      Hello I checked the link..So we could actually get the values of force from reports as mentioned in the link. But the problem we have to pause the iteration each time and go to the report for getting the value..So if we need let's say force for 100 time periods,we have to stop iteration 100 times and go check the report values and plot the graph manually...Does there exist anyother method or any software in which we will be able to plot force Vs time..
      No, read up on transient monitors and plot the result to a graph. That (if you do it correctly) will output time on the x-axis and force on the y.
      Fluent can do that as you read the out file back into it.
    • Vishnuraja
      Hi guys I dnt understand. All I can find in fluent is force coeff in monitors..Could you guys please suggest any threads or links regarding the way to plot force Vs time as you have mentioned in the previous replies.
      Hey search after force in the help related to your working version. And look into https://confluence.cornell.edu/display/SIMULATION/Flow+over+an+Airfoil+-+Numerical+Results
Viewing 13 reply threads
  • The topic ‘Plotting force Vs time on fluent’ is closed to new replies.
