June 10, 2021 at 5:01 pm
wmatava
SubscriberJune 18, 2021 at 3:27 pmcbiurrun
SubscriberHi!
I guess you are generating a dispersion diagram by sweeping a phase delay between the Primary and Secondary boundaries, correct?
Please be aware that for each phase value you will get up to N frequency values , one per mode. If you plot re(mode(n)) against this phase delay you will obtain a diagram and you will see how each phase value corresponds to a frequency value for each mode. That is why you don't have a "frequency" section.
If you want to plot the fields for a specific mode and at a specific frequency, you should simulate the adequate phase value and then you should be able to obtain a field representation and to animate it.
Viewing 1 reply thread- The topic ‘Plotting fields from eigenmode analysis produces no visuals’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3872
1414
1241
1118
1015
