Ploting results with only certain elements – APDL
    • sanadros
      I'd like to plot stress results of just a bunch of elements let's say of the elements no 10920, 10000, 10080. How can I write an APDL code with just these elements showing stress.
    • Sandeep Medikonda
      Hi, Are you looking for a contour plot or a history x-y plot?
    • Samir Kadam
      For this,
      1) Create an Elemental Component of these elements using CM command.
       2) Select this Elemental Component using CMSEL command.
      3) Under /Post1, select last result set.
      4) Plot above selected Elements (under elemental component) using EPLOT.
      5) PLESOL,S,EQV for plotting stress results and PRESOL,S,EQV for printing stress results of selected elements.
      Samir.
    • sanadros
      I think I was not precise enough. I have a simulation with extreme stresses at the boundary when I plot the nodal solution. So what I want to do is to exclude these elements at the boundary. Therefore I want to pick some elements in the middle and plot these stresses. I coded Samirs suggestion like this
      CM, MYELEM, ELEM
      CMSEL, S, MYELEM, ELEM
      EPLOT
      PLESOL,S,EQV
      Where I get all elements. Where can I get just my certain elements?
      This code also doesen't function (as it is a violation to the CMSEL command):
      CM, MYELEM, ELEM
      CMSEL, S, 10920, ELEM
      CMSEL, S, 11000, ELEM
      CMSEL, S, 11080, ELEM
      EPLOT
      PLESOL,S,EQV
    • Rohith Patchigolla
      Hi Sanadros,
      As Samir suggested, you would need to select the elements first before creating the component (step 1).
      Please try the below scripts.
      Without component:
      esel,s,,,10920
      esel,a,,,11000
      esel,a,,,11080
      plesol,s,eqv
      With component (for reuse):
      esel,s,,,10920
      esel,a,,,11000
      esel,a,,,11080
      cm, myelem,elem
      cmsel,s,myelem,elem
      plesol,s,eqv
      Also, may I ask, if there is any reason to do the modelling/post-processing in APDL instead of Mechanical?
      Best regards,
      Rohith
    • sanadros
      ah esel does the magic thx. The reason for APDL is that a similar script exists before I was dealing with this project in APDL and APDL turned out to be useful, using it in a parameter study where I write the the commands in Matlab and then hand it over to Ansys and then get back the data. I will implement this in my code and see if it runs.
    • sanadros
      Ok at the end I adjusted the solution to my needs and used a location approach based on nodes found on xansys:
      NSEL,S,LOC,X,19.000000,21.000000,
      NSEL,R,LOC,Y,13.000000,16.000000,
      ESLN,S,1
      PLNSOL,S,X,
      NSEL,ALL
      ESEL,ALL
      The advantage of the location approach is that I don't need to know all element numbers. The disadvantage is that I need to know approximately where the elements are.
Viewing 6 reply threads
  • The topic ‘Ploting results with only certain elements – APDL’ is closed to new replies.
