Plot the “Elastic Strain Energy Density” (PLESOL,SEND,ELASTIC)
    • ThomasDD
      It seems the "Elastic Strain Energy Density" is not written by default in the RST. When I try to plot it with PLESOL,SEND,ELASTIC, I get an error message (see image).
      What do I need to activate to can plot the "Elastic Strain Energy Density"? Thanks!
    • ThomasDD
      I use Solid185 elements. In the manual of Solid185 I can read, SEND is available, if nonlinear material is used. And I use an elastic-plastic material. I can plot the plastic strains (EPPL) for example, but not SEND...
    • Erik Kostson
      HI
      Try perhaps before solving to issue,
      /SOLU
      outres,all,all
      All the best
      Erik
    • ThomasDD
      It seems I have it. It is a version conflict. I always thought Ansys was backwards compatible, i.e. I can open older RST files with a newer Ansys version. But that doesn't seem to work completely. Certain result variables cannot be accessed when loading older RST files. I have repeated the calculation with the current Ansys version that I am using. And now I have access to the Elastic Strain Energy Density.
