August 28, 2024 at 12:57 pm
rene.fabrice.nshuti
SubscriberHello.
I have performed a thermal transient analysis. The time is composed of 2 types of steps: small and big steps. The simulation time is 0.05 sec. From 0 to 0.005 sec, the time step is 0.0001 sec and from 0.005 to the end, the time step is 0.0005 sec.
When I try to plot the results, for instance the temperature, the plot doesn't show results from 0 sec on the time axis.
However, when I track the global temperature. I can see, it is starting from 0 sec.
I have tried different techniques like store results at all time points, specified recurrence rate and also added an apdl commandÂ
/solu
allsel,all
OUTRES,ERASE
OUTRES,basic,all
OUTPR,basic,allBut nothing changed.
I would appreciate to solve this issue.
Thanks.
August 29, 2024 at 1:26 pm
danielshaw
Ansys EmployeeThere is no solution at time=0. For the MAPDL solver all time points must be positive and greater than zero. If you want a near zero solution, begin with a very small initial time step.Â
