February 6, 2024 at 10:38 am
February 7, 2024 at 10:44 am
Reshmi Raghavan
Ansys EmployeeHello Hemant,
Could you please let me know what is the query.
Timos
Ansys EmployeeHello, could you please let us know what kind of issue you are facing?
February 7, 2024 at 12:09 pm
Hemant Chaudhari
SubscriberÂ
my project is bldc motor design,i am trying to plot full project instead 1/6th part of my project.Â
First build in RMxrt then convert to Maxwell -
February 7, 2024 at 1:25 pm
Reshmi Raghavan
If you want to generate a full model in Maxwell from RMxprt please add the command "Fractions 1" in the design setting of RMxprt under user degined premitive. Analyze the RMxprt model and then generate the Maxwell model.
If you want to plot the mesh on the full model in Maxwell while using a sectioned model then enable the option Full model while plotting the mesh or field as shown in the below snapshot.
February 8, 2024 at 7:04 am
Hemant Chaudhari
SubscriberHow to add fractions? there is any tutorial for add fractions?Â
February 8, 2024 at 8:37 am
February 8, 2024 at 8:55 am
Hemant Chaudhari
Subscriberthank you
February 11, 2024 at 6:29 pm
Hemant Chaudhari
SubscriberI am Facing this error,"Sweeping curves cannot be preserved." please give me solution...
February 12, 2024 at 4:01 am
Reshmi Raghavan
Sweeping curves cannot be preserved error message generates because of the geometry. Please try non modelling one part at a time and simulate to identify the part causing the issue. Then try resolving this part.
February 12, 2024 at 8:12 am
Hemant Chaudhari
Subscriberif generated full model so there shows Sweeping curves cannot be preserved error & if plot 1/4th part of model so there is not shows that error.Â
so, for full model have any solution for this error?
- The topic ‘plot mesh’ is closed to new replies.
6034
.png)
