September 22, 2021 at 2:50 am
FaizanYounas
SubscriberHi. I'm modeling
September 22, 2021 at 10:21 amRob
Forum ModeratorWhat are you including in the model? Phase change and bubble expansion may require something else switching on. As an aside, /forum/discussion/23093/why-ansys-employees-dont-download-attachments
September 22, 2021 at 11:47 amFaizanYounas
SubscriberSeptember 22, 2021 at 12:15 pmRob
Forum ModeratorIs there a value or is it reporting zero? Note, you've also only run for 0.006s so it may not have started boiling?
September 22, 2021 at 1:55 pmSeptember 22, 2021 at 2:50 pmRob
Forum ModeratorYou're reporting the "volume" of the mixture in one fluid region. Set to report the volume of the gas phase in the both fluid regions.
September 22, 2021 at 9:31 pmSeptember 23, 2021 at 1:42 pmKarthik Remella
AdministratorHello This is a 2D simulation. So, the volume is going to be pi*r^2*1 m (Fluent considers the depth into the plane as 1 m in the z-direction) and not 4/3 * pi* r^3.
Karthik
September 24, 2021 at 5:47 amFaizanYounas
SubscriberAhh, I see. The problem is the research paper that I'm following performed 2D simulations and calculates the volume by 4/3*pi*r^3. Or, maybe they just multiplied by a factor of 2 after using pi*r^2. I don't know. Anyways, thank you very much
September 24, 2021 at 1:16 pmKarthik Remella
AdministratorYou are welcome!
Viewing 9 reply threads- The topic ‘Plot Flow Time vs Volume in Fluent?’ is closed to new replies.
5734
