Electronics
Electronics
Plot ‘B_Vector_bottom’ becomes invalid due to no available solution
    • JASPERk
      i get the error Plot 'B_Vector_bottom' becomes invalid due to no available solution after analysing a geometry and wanting to plot the b field of a particular region.
      What does this error mean? how can it be solved?
    • NurAmirah1
      Have you find the reason behind it? I also have the same problem but with voltage excitation on electrostatic solution type. n
    • NKC
      Hi,ncan you provide some screenshots on how your setup and mode is and where in the region you want to plot the B fields?nThis way I can understand your problem better.nnRegardsnNavyan
  • The topic ‘Plot ‘B_Vector_bottom’ becomes invalid due to no available solution’ is closed to new replies.
