Electronics
Electronics
Please tell me the Y wiring circuit diagram.
    • jjh4804a
      I want to analyze a 12 slot 8 pole motor.
      I want to do it with a Y final, but I don't know how.
      I analyzed it by dividing it into Winding_A, B, and C as shown in the image below, but the back electromotive voltage waveform came out strangely.
      (The coils were divided into groups by the same color.)
      I want to first analyze the back electromotive voltage.
      Later, we plan to analyze torque, efficiency, voltage, and current.
      How can I modify the circuit diagram?
      If possible, please let me know with an image. Thank you.
    • GLUO
      For back EMF, you can use 0 current source to make the motor "open circuit", and measure the induced voltage.
      GL
      • jjh4804a
        The voltage is set to zero. Can you judge if there is a problem with the circuit diagram I made? I want to connect with a Y-line.
        • GLUO
          You need to set current as 0, not voltage. Your circuit looks fine, if you have a connected neutral.
        • jjh4804a
          The current was also set to 0.
          When analyzed, the graph is not consistent and the desired value is not obtained. Is there a way to do Y wiring without using a circuit diagram?
          When u, v, and w are grouped and interpreted, the graph is constant, but the back electromotive voltage value does not appear.
        • GLUO
          Your circuit is already a Y connection with neutral. Without external circuit there is no connection inbetween windings, the excitations are only voltage or current applied on the windings. Back EMF is the induced voltage on windings in open loop condition, which is represented using 0 current. Please check other factors like magnet polarity.
        • jjh4804a
          Is it possible to make Y connection in the next setting?
          Excitations>Setup Y Connection.
        • GLUO
          This feature does not support current source. User must use 0 amp current source for back EMF simulation.
        • jjh4804a
          Then, I wonder what kind of connection it will be if we interpret only the winding group as u,v,w without creating an external circuit.
