Please tell me how to model concrete foundation rested on limestone sand layer in Ansys workbench?
    • abdalla
      Dear StaffnPlease tell me how to model the bond slippage between concrete and steel bars by Ansys workbench?n
    • 1shan
      nA Combin39 element can be added between the bar element node and the concrete element node to consider the bonding slip at the bar-concrete interface. You can refer this article on use of combine39 https://jce-ieb.org/doc_file/3902005.pdf. Also, check the help documentation COMBIN39 (ansys.com) and
      for details on implementing non - linear spring using command snippets in ANSYS workbench.nRegards,nIshan.n/forum/discussion/3978/how-to-access-the-ansys-online-help n
  • The topic ‘Please tell me how to model concrete foundation rested on limestone sand layer in Ansys workbench?’ is closed to new replies.
