February 5, 2023 at 5:21 am
H Nor
SubscriberWhat im trying to do is a reinforced concrete beam column joint. and at the node 665, where i made all of the individual RC element by nodes. im not sure what is the problem here. Node 665 is just tbetween the connection of beam and column. so im not sure what is the problem here. Im new to ansys in general.
February 5, 2023 at 5:50 am
H Nor
SubscriberÂ
https://shrib.com/?v=co#Cade80oAQv7 Â Â , the link to my model. The node value might change, because i tried to remove some of the commands so that it can be copy/paste and process more easily
February 21, 2023 at 7:43 am
Rahul Kumbhar
Ansys EmployeeHi, what kind of connection are you using to connect beam and column? Normally beam has 6 DOF and solid element has 3 DOF. The error may appear because of this.Â
February 22, 2023 at 12:38 am
H Nor
Subscriberi made the element individually by solid65 for the whole beam column joint. which then i created new element of link180 for the rebar and stirrups and applied it at the existing nodes.
- The topic ‘Please check for an insufficiently constrained model’ is closed to new replies.
