April 18, 2024 at 8:09 pm
blmcdona
SubscriberI am subjecting a simply-supported steel beam to an acceleration in Harmonic to simulate the effects of earthquakes, in which the beam yields. Is there a way to insert a plastic strain object in the solution section? I am able to determine deformation, stress, and total strain, but not plastic strain.
April 19, 2024 at 6:27 am
ErKo
Ansys EmployeeÂ
Hi
Harmonic analysis is a linear type, hence we can not include nonlinearities such as material nonlinearities.
You can use a full transient analysis imposing a transient earthquake load/accel., and then also have and use nonlinear material, and look at plasticity (e.g., plastic strains).
All the best
Erik
April 23, 2024 at 3:17 pm
blmcdona
SubscriberI am using transient analysis for earthquake. However, I am not getting plastic strain due to the following issue:
"All nonlinearities are ignored while solving the MSUP transient systems."
Is there a way to have mode superposition include nonlinearities?
April 23, 2024 at 11:47 pm
peteroznewman
SubscriberIn Workbench, if you have linked the Solution cell of a Modal analysis to the Setup cell of a Transient Structural model, you have a MSUP setup.
Delete the link and the Transient Structural will become a Full Transient setup.
The MSUP is a linear analysis so there is no way to include nonlinearities.
- The topic ‘Plastic Strain in Harmonic for Earthquake’ is closed to new replies.
5939
1307
