September 20, 2023 at 7:55 pm
javat33489
SubscriberHi all. Colleagues, share your experience. How often do you use plastic (plastic properties of steel) when calculating metal frames using the beams and shells method? How necessary is this? I think we can get by with isotropic properties.
September 20, 2023 at 8:44 pm
Ankush Choudhary
Ansys EmployeeHi Javat,
It depends on the loading conditions. If the material remains below the yield stress, then its elastic properties are sufficient. However, if the loading exceeds the yield stress in the material, then it is better to use elastic-plastic material properties for the analysis.
For further information, you can check out this AIS course.
/courses/index.php/courses/metal-plasticity/
September 22, 2023 at 6:32 pm
javat33489
SubscriberThanks for the answer. I saw this course. I was interested in people's experiences and their words. Thank you, it's clear now.
- The topic ‘Plastic in beams and shells’ is closed to new replies.
3402
1052
1050
886
857
