Plasma capabilities in ANSYS
    • wbmckinney
      I was wondering if ANSYS is capable of modeling low-temperature plasma? If so, what modules or solvers would be used? Please let me know if anyone has any thoughts.
    • pgl
      It depends on the pressure regime, are you talking continuous or molecular flow vacuum/pressure levels?
      For continuous flow, ANSYS Fluent is a good choice. There are quite a few papers/article in the public domain where ANSYS Fluent is used to model plasma arcs. Most of these are high temperature plasma in that they have welding applications. Example.
      At the other extreme, these folks used our simulation tools to model a plasma contained within the W7-X cryostat plasma vessel (PV). There's a paper published here by Elsevier.  I'm not sure what blend of solvers they used, but either ANSYS Maxwell or legacy ANSYS Emag can be used to model charged particle traces. Some users have also simulated high vacuum by using a thermal solution analogy.
      W7-X cryostat system are the plasma vessel (PV),
    • Raef.Kobeissi
      That looks awesome! The paper is definitely worth an in-depth read! Thanks for sharing
    • wbmckinney
      Thank you for the reply. However, I do not believe these are applicable to my situation as I am trying to model low-temperature atmospheric plasma via dielectric barrier discharge through a tube.
    • Mostafa
      Can i use Ansys Chemkin in DBD plasma Simulation?
    • Mostafa
    • Naman Tibrewal
      What module of ANSYS fluent will be used to simulate plasma impulse bits in space from propulsion thrusters? Please respond as soon as you can
Viewing 6 reply threads
  • The topic ‘Plasma capabilities in ANSYS’ is closed to new replies.
