3D Design
3D Design
Plane perpendicular to a curve.
    • daniel.nouxet
      Dear all,
      I try yo make a plane perpendicular to a curve at a specific point.
      Is it possible natively ?
          if not, do I have any chance to obtain a C# function for this ?
      My concern is gong to a section mode in a plane perpendicular to a curve at a specific point.
      Best Regards.
      Daniel
    • Naresh Patre
      Hello dNouxet
      You can first split the curve at a specific point using Split tool. Then hide one curve and select the end point (the point where the curve was split) and click the Plane tool. This will create a plane normal to the curve at the selected point. You can now use this plane for sketching.
  • The topic ‘Plane perpendicular to a curve.’ is closed to new replies.
