3D Design
3D Design
Placing note issue
    • benjamin
      When i try to add a note i'm not able to add the note, it only places the plane:
    • mohan.urs
      Hey,
      Can you check out this post and try the same once ?
      Note and BOM are not created – SpaceClaim (ansys.com).
      If it doesn’t work can you share which version are you using.
      Thanks.
    • benjamin
      Ive tried that already, thats also not an option cause they are using momentum.
      Already deleted all files in %localappdata%\spaceclaim doesnt work
      Also reset the usersettings doesnt work.
    • Devendra Badgujar
      Hi Benjamin,
      Can you please try hiding the Properties panel, either by making another tab active, or disabling in File>Options and let me know if that helps? We saw this problem previously so wanted to confirm:
      Devendra
    • benjamin
      Thanks Devendra, that worked!
Viewing 4 reply threads
