February 1, 2024 at 11:31 pm
Micah Clarke
SubscriberHello everyone,Â
I'm fairly new to Ansys and am having issues when running my solver. It works fine when my materials have low resistivity (0.001-10,000 ohms.m) but as soon as it goes over around 1e7 I have solver pivot errors due to unrealistic material properties and solver pivot warning or error detected in the VOLT degree of freedom in nodes in the material with high resisitivty. Any help is appreciated. Thank you
February 7, 2024 at 12:37 pm
Reshmi Raghavan
Ansys EmployeeHello Micah,
May I know what is the objective of the simulation that you are trying to carry out?
With a high resistivity or low conductivity value the material characterisitc of the material moves towards an insulator. Maxwell consideres a component as insualtor if the conductivity is less than 1 Siemens/m.Â
In you model are you changing the inputs in design setting for the insulator definition?Â
February 11, 2024 at 9:16 pm
Micah Clarke
SubscriberHi Reshmi,Â
Thank you for your response. I am just looking at the electric field between two copper plates. I when the enclosure has a material of air with a resistivity of over 10^7 ohm m it causes pivot errors. Similarly any dielectric material I place anywhere in the simulation (ideally between the plates) with a high resistivity causes the same issues. In the model I'm changing the resisitivity value in the material properties and then re-reading the upstream data
February 12, 2024 at 4:05 am
Reshmi Raghavan
Could you please let me know the solver you are using?
February 15, 2024 at 1:17 am
Micah Clarke
I have tried iterative and computer controlled and both have the same problems associated
February 15, 2024 at 11:14 am
Reshmi Raghavan
Please let me know if you are doing this simulation in Electrostatic solver / DC Conduction or eddy current solver.
February 18, 2024 at 9:42 pm
February 22, 2024 at 10:10 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: * Error* there is at least 1 small equation solver pivot term (eg. VOLT DOF of node 575) (ansys.com)
Ashish Khemka
February 22, 2024 at 12:31 pm
Micah Clarke
SubscriberHi Ashish, I have seen that thread before and was wondering if there was any way without macros as that is something I have no experience in and would not know how to use at all.
Thanks
February 24, 2024 at 5:16 pm
dlooman
Ansys EmployeeAssuming the volt dof is constrained somewhere, this is usually caused by large differences in the resistivity. There are only so many significant figures in a numerical analysis (~16) and when material properties vary by more than say 12 orders of magnitude you run into that fact of life. Sometimes users specify an arbitrarily large value of resistivity to model a non-conductor like air or water. A value of 1.0 is already an extremely large resistivity and the results will be more or less the same with a value of 1.0 as with 1.0e12. Â
- The topic ‘Pivot error – Ansys Electrical’ is closed to new replies.
6545
1311
