October 27, 2018 at 2:44 pm
October 27, 2018 at 3:29 pm
peteroznewman
SubscriberHello Sam,
First change, make sure there are 2 elements across the thickness of any part by setting Proximity to Yes and Num Cells Across Gap to 2.
Second change, put a Contact Tool into the Connections folder and Generate Initial Contact Results.
All the contacts are Closed, so now I tried to Solve, but I got that same error. The next step is to add a Modal analysis to find the loose part.
Drag the Fixed Support from the Static Structural branch and Drop it on the Modal branch.
Solve the Modal system and plot the Total Deformation. It shows one loose part.
Add contacts for the loose body, then the Static Structural model will solve (and the Modal will have a non-zero frequency for the first mode).
Now you can delete the Modal analysis, it did its job.
A bonus tip: the default mesh looked like this:
I added a Multizone method to the two lower angle brackets and they came out as shown in the Deformation contour plot.
Peter -
October 27, 2018 at 5:23 pm
Sam Fares
SubscriberThank you so much Peter!
i need to understand on my own if i can what each step you performed does or mean. i 'd like to ask you more questions as i try to grasp your steps.
Could you send both files the one with modal analysis and the one after you removed the modal analysis?
Sam
October 27, 2018 at 5:44 pm
peteroznewman
SubscriberSam,
Here is the 19.2 archive with the Modal analysis. You can delete the Modal whenever you want.
Peter -
October 27, 2018 at 9:39 pm
Sam Fares
SubscriberThank you Peter!
October 29, 2018 at 2:10 am
October 29, 2018 at 2:50 am
peteroznewman
SubscriberHi Sam,
Restart your computer, download to a new folder, rename the download to temp.wbpz and try Restore Archive again.
I was successful opening the file attached to my last post.Regards,
October 29, 2018 at 8:13 pm
Sam Fares
SubscriberThank you Peter! It worked.
Few questions:
1. How does Modal analysis find the loose part? or what is it about the modal analysis that fined the loose part? Â
2. You stated to " Setting Proximity to Yes and Num Cells Across Gap to 2". What does that do or mean? Why isn't the program default to these? Are there condition where this setting is not right?
3.Do you always add a Multizone method? what does Multizone method do?
Sam
October 29, 2018 at 9:41 pm
Sam Fares
SubscriberHi Peter,
1. Below you added Multiple to Multiple bonded contact. 2 bodies with 5 faces. I can see each fillet weld can be welded to two faces for a total of 4 faces.One face is the thickness of slotted angle and the other face is the vertical plate of top chord angle. could you tell me what is the fifth face?
2. Is there a difference between Bonded contact and shared topology?
Sam
October 31, 2018 at 12:45 am
peteroznewman
SubscriberHi Sam,
Modal analysis can be done for parts that are not fixed to ground, like rockets and planes. Static Structural requires a connection to ground or it won't solve. Therefore, you can use Modal analysis to find loose parts.
Proximity = Yes means the meshing software will look at faces that are near each other. Num cells across gap means when two faces are near each other and there is a gap between them, the mesher will put two elements across that gap. This is only useful sometimes, like when you have thin walled parts, so is not the default.
If you mesh without Multizone, you will get a Tetrahedral mesh that will take about twice as many elements to fill the volume than would be required if you use Multizone, which breaks the volume up into sweepable pieces and meshes them with hex elements. Multizone doesn't always work. When it fails, you can either use Tetrahedral elements or spend a lot of time manually slicing up the geometry into sweepable pieces.
I picked all four faces of the slot, plus the face of the other angle bracket to get 5 faces on one side of the contact. I could have picked just 3 faces to get what was needed, but the faces that were needed were behind the weld bodies and there is an icon on the toolbar called Extend to All which lets me pick the cylindrical face, click that button to get the other three, then Ctrl-click the last face.
Bonded contact and Shared Topology have similar outcomes.
Peter -
October 31, 2018 at 9:21 am
Sam Fares
SubscriberBig thanks to you Peter!
Sam
- The topic ‘pivot error and model won’t run’ is closed to new replies.
5639
1885
1403
1303
