November 6, 2020 at 6:17 am
Lugia_06
SubscriberHi everyone,
I developing a transient droplet falling simulation model and play around with the Presure-Velocity Coupling methods, Coupled and SIMPLE both converged at the 3rd time steps and gave good results. However, the PISO method all three residuals are diverging. The Fluent theory guide introduced PISO as a part of the SIMPLE family and the skewness & Neightbour correction factors give higher efficiency. Could anyone assist me understand why PISO is diverging with the other settings the same as SIMPLE & Coupled?
Best regards,
Lugia_06
PISO
November 6, 2020 at 8:00 amAmine Ben Hadj Ali
Ansys EmployeeSIMPLE is very under-relaxed PISO Not. You might tune Pressure URF for PISO (increase to 0.7) for Mometum (decrease it to 0.3) but I do not recommend doing that all the time.n If Coupled is providing you the required satisfaction then stick to it or does it last long time for your case?nNovember 6, 2020 at 8:32 amAmine Ben Hadj Ali
Ansys EmployeeJust one question: Why CICSAM?nNovember 6, 2020 at 9:31 pmLugia_06
SubscribernIt's good to see you on the forum again. The convergence in SIMPLE and Coupled both last for a long time. I will stick to coupled in this case. According to the Fluent theory guide, CICSAM is more suitable for flows with high ratios between phases(water vs air) (https://www.afs.enea.it/project/neptunius/docs/fluent/html/th/node299.htm) and I have tested with Geo-reconstruct as well, there wasn't any difference between them. So I was wondering if you have any recommendations on the discritisation schemes I used in the screenshot?nBest regards,nLugia_06nViewing 3 reply threads- The topic ‘PISO vs SIMPLE & Coupled solvers’ is closed to new replies.
5094
1830
1387
1248
