May 12, 2022 at 8:12 pm
Sand_1234
SubscriberHi,
My 3D model has a pin connection on one end and roller at the other end.
For Pin, I used Displacement boundary condition and gave the value of 0 for x, y and z axes.
For roller, I used Displacement boundary condition and freed x and set y and z to 0.
I am wondering if this a right way to represent pin and roller support? Are moments automatically released ?
Thank you for your help!
May 12, 2022 at 9:42 pmpeteroznewman
SubscriberWhat did you select to apply the Displacement BC? If it was a face, then it is no longer a pin. If it was an edge, that creates high stresses on that edge.
Delete the two displacements and replace them with two Remote Displacements.
On the Pin end, you can constrain X, Y, Z to 0 and leave all the rotations Free.
On the Roller end, you can leave X Free and set Y and Z to 0 but you also need to set RX to 0 to prevent the body from spinning about the two ends.
Each Remote Displacement is scoped to an end face so there is no high stress at the ends.
May 18, 2022 at 1:44 pmSand_1234
SubscriberThank you for the information.
Viewing 2 reply threads- The topic ‘Pin and Roller connection’ is closed to new replies.
5264
1859
1398
1256
