piezoelectric element
    • judy
      I want to see the voltage produced by applying pressure to the piezoelectric element.
      Attempting to insert a voltage into the solution tab does not activate.
      What kind of conditions do I have to choose?
      (I use ACT_ Piezo And MEMS)
      Or what's the problem?
      Please help me.
    • kevin1704
      Excuse me, I am a new user here, could you tell me how to find out the piezoelectric materials?
    • judy
      Hello, When you open Workbench, you can see Extension at the top section. Then you can click Extensions Manager. Check PiezoAndMeMs and close. Finally I think you can start analysis with piezoelectric materials.
    • kevin1704
      Thank you very much Judy
    • alicepicci
      Hi Judy,nDid you find the way to insert Voltage into the solution?nI have the same problem as you.nn
Viewing 4 reply threads
  • The topic ‘piezoelectric element’ is closed to new replies.
