Piezoelectric electric using ANSYS mechanical workbench
    • Mahmoud Nassar
      I'm trying to simulate a PZT using ANSYS mechanical workbench.
      I have downloaded the ACT successfully. Now I am trying to duplicate the results for the “Piezoelectric fan” found in the documentation, but I failed. I am stuck for a long time and I do not know what I am doing wrong?!!!
      For Example:
      In the modal analysis, the answer is [Mode1 = 60.142 HZ, Mode2 = 349.28 HZ]. For me, I get [Mode1 = 59.949 HZ, Mode2 = 333.12 Hz]
      Further, for the frequency response, I get a completely different plot than the one in the documentation and have no idea why !!!!
      Note: I am using ANSYS 2020
      Any help will be appreciated
    • Erik Kostson
      Hi
      THe act extension is not supported and developed longer.
      Use the coupled field modal and harmonic to analyse Piezoelectric+structure+acoustics (if needed).
      For an example see technology demo or showcase TD39: Wire Bonding with Ultrasonic Transducer
      All the best
      Erik
    • Mahmoud Nassar
      Thank you for your reply
      My goal was to solve the piezoelectric in an FSI problem (FlUENT+ Transient Structure). So, I had first to validate an ANSYS problem (Modal + Harmonic).
      To be on the same page, do you mean this video where he is using the ACT (Piezo & Mems):
      https://www.youtube.com/watch?v=TuQGOMnDtDI
      or am I wrong ?!
      Thank you
    • Erik Kostson
      It is perhaps the same or similar model – but what I refer to is td39 in the help manual (search for that title in the ansys help manual: Wire Bonding with Ultrasonic Transducer) and using the native coupled field system – as we said the act mems is not supported anymore by us.
      All the best
      Erik
    • Mahmoud Nassar
      Oh, I see that now
      Thank you, that is really helpful.
    • Mahmoud Nassar
      can we use a Coupled Field Transient (Piezoelectric with transient structure) in system coupling with FLUENT?!!!
      I am trying to do that but I keep getting errors, the coupling is not working!!
    • Erik Kostson
      Hi
      It is there and possible to use from 2023 R1.
      See the 2023 R1 help manual under the system coupling user guid and section:
      Supported Coupling Participants for System Coupling in Workbench
      All the best
      Erik
Viewing 6 reply threads
  • The topic ‘Piezoelectric electric using ANSYS mechanical workbench’ is closed to new replies.
