Piezo and MEMS extension – Electric flux density
    • yuen
      I installed Piezoelectric and MEMS extension. I used this extension regularly and it has been really good.
      Recently, I simulated a piezoelectric tube and would like to compute the electric flux density of an area on the tube as shown below under under strain.
    • dlooman
      It should be available. Check your Output Controls in Analysis Settings. Adding a commands object to the Static Structural with outres,all,all would be a way to make sure all types of results are written to the results file.n
    • yuen
      Thanks. The command object works.n
  • The topic ‘Piezo and MEMS extension – Electric flux density’ is closed to new replies.
