Physical properties of material defined via APDL command
    • yu272
      I am simulating a solid where the material property is defined via APDL command (select solid - insert command - use TB to define material constants, where the default material selected is structural steel). Therefore, the material behavior is completely overwritten by the material model and parameters I input. In this case, how do I add/modify more physical properties such as density?
      Sincerely,
      Eric
    • ErKo
      Hi
      See the MP command in the help manual.
      Also here is a discussion similar to yours:
      /forum/forums/topic/workbench-mechanical/
      All the best
      Erik
      • yu272
        Thanks Erik!
  • The topic ‘Physical properties of material defined via APDL command’ is closed to new replies.
