TAGGED: Diffractive optics, gaussianbeam, lens, optics, OpticStudio, python
February 5, 2024 at 12:28 am
Nishtha.Chopra
SubscriberHi, does anyone know if there is a way to automate saving multiple beam files ? For instance, I have several surfaces and for now I am generating a beamfile for each surface and saving it manually. It is a slow process especially when there are 20 surfaces for which I need the beamprofile. Is there a way to automate this using python ?
February 5, 2024 at 9:23 am
Elham Sarbazi
Ansys EmployeeHi Nishtha,
Thanks for posting here in the forum.
Pysical Optics Propagation (POP) allows you to save multiple beam files in .ZBF format. In the Display Tab, you can check the options Save Output Beam To and Save Beam At All Surfaces and the individual surface beam files will be stored in the POP folder at \Zemax\POP\BEAMFILES\. The files will be named according to the provided file name, with a suffix indicating the surface number.
- The topic ‘physical optic propogation module in Zemax Optics Studio’ is closed to new replies.
5649
1885
1404
1303
