March 14, 2023 at 10:19 pm
minusunny
SubscriberHello everyone,
Is it necessary all the time to use unwrap function while extracting the phase information ? I am getting almost the correct value for phase without using unwrap function and when i use that i am getting a bizarre value for angle.Â
March 16, 2023 at 11:09 pm
Guilin Sun
Ansys EmployeeIn general it is not necessary to use "unwrap", except that you want to have a continuous curve as a function of some parameter. The "unwrap" function creates phase based on a reference point, usually the first frequency point if the result is for phase vs frequency. When the reference point changes the result will change.
- The topic ‘unwrap command for angle extraction’ is closed to new replies.
