Photonics
Photonics
Phase optimization of 2×3 MMI using Lumopt is ineffective.
    • longch
      We modified the modematch code and added phase control to the optimization objective to achieve the inverse design of a 2x3 MMI device. When two mode light sources enter through two input ports respectively, we aim to obtain equal power at the three output ports with a phase difference of 120°. However, we observed that the actual FOM curve does not trend towards a gradual reduction in insertion loss, and the phases of the monitors at each port are all 0 as the number of optimization iterations increases. Why is this the case? Please provide me with professional advice and assistance. Thank you!
      code of modematch:
      """ Copyright chriskeraly
      Copyright (c) 2019 Lumerical Inc. """
      import sys
      import numpy as np
      import scipy as sp
      import scipy.constants
      import lumapi
      from lumopt.utilities.wavelengths import Wavelengths
      """ Helper function to determine if a variable can be converted to an integer """
      def is_int(x):
      try:
      int(x)
      return True
      except ValueError:
      return False
      class ModeMatch(object):
      """ Calculates the figure of merit from an overlap integral between the fields recorded by a field monitor and the slected mode.
      A mode expansion monitor is added to the field monitor to calculate the overlap result, which appears as T_forward in the
      list of mode expansion monitor results. The T_forward result is described in the following page:
      https://kb.lumerical.com/ref_sim_obj_using_mode_expansion_monitors.html
      This result is equivalent to equation (7) in the following paper:
      C. Lalau-Keraly, S. Bhargava, O. Miller, and E. Yablonovitch, "Adjoint shape optimization applied to electromagnetic design,"
      Opt. Express 21, 21693-21701 (2013). https://doi.org/10.1364/OE.21.021693
      Parameters
      :param monitor_name: name of the field monitor that records the fields to be used in the mode overlap calculation.
      :param mode_number: mode number in the list of modes generated by the mode expansion monitor.
      :param direction: direction of propagation ('Forward' or 'Backward') of the mode injected by the source.
      :param multi_freq_src: bool flag to enable / disable a multi-frequency mode calculation and injection for the adjoint source.
      :param target_T_fwd: function describing the target T_forward vs wavelength (see documentation for mode expansion monitors).
      :param norm_p: exponent of the p-norm used to generate the figure of merit; use to generate the FOM.
      :param target_fom: A target value for the figure of merit. This allows to print/plot the distance of the current
      design from a target value
      def __init__(self, monitor_name, mode_number, direction, target_phase=0, power_weight=1.0, phase_weight=1.0, multi_freq_src = False, target_T_fwd = lambda wl: np.ones(wl.size), norm_p = 1, target_fom = 0):
      self.monitor_name = str(monitor_name)
      if not self.monitor_name:
      raise UserWarning('empty monitor name.')
      self.mode_expansion_monitor_name = monitor_name + '_mode_exp'
      self.adjoint_source_name = monitor_name + '_mode_src'
      self.mode_number = mode_number
      self.target_fom = target_fom
      # 新增参数...
      self.target_phase = np.radians(target_phase) # 转换为弧度
      self.power_weight = power_weight
      self.phase_weight = phase_weight
      if is_int(mode_number):
      self.mode_number = int(mode_number)
      if self.mode_number <= 0:
      raise UserWarning('mode number should be positive.')
      else:
      self.direction = str(direction)
      self.multi_freq_src = bool(multi_freq_src)
      if self.direction != 'Forward' and self.direction != 'Backward':
      raise UserWarning('invalid propagation direction.')
      target_T_fwd_result = target_T_fwd(np.linspace(0.1e-6, 10.0e-6, 1000))
      if target_T_fwd_result.size != 1000:
      raise UserWarning('target transmission must return a flat vector with the requested number of wavelength samples.')
      elif np.any(target_T_fwd_result.min() < 0.0) or np.any(target_T_fwd_result.max() > 1.0):
      raise UserWarning('target transmission must always return numbers between zero and one.')
      else:
      self.target_T_fwd = target_T_fwd
      self.norm_p = int(norm_p)
      if self.norm_p < 1:
      raise UserWarning('exponent p for norm must be positive.')
      def initialize(self, sim):
      self.check_monitor_alignment(sim)
      ModeMatch.add_mode_expansion_monitor(sim, self.monitor_name, self.mode_expansion_monitor_name, self.mode_number)
      adjoint_injection_direction = 'Backward' if self.direction == 'Forward' else 'Forward'
      ModeMatch.add_mode_source(sim, self.monitor_name, self.adjoint_source_name, adjoint_injection_direction, self.mode_number, self.multi_freq_src)
      def make_forward_sim(self, sim):
      sim.fdtd.setnamed(self.adjoint_source_name, 'enabled', False)
      def make_adjoint_sim(self, sim):
      sim.fdtd.setnamed(self.adjoint_source_name, 'enabled', True)
      def check_monitor_alignment(self, sim):
      ## Here, we check that the FOM_monitor is properly aligned with the mesh
      if sim.fdtd.getnamednumber(self.monitor_name) != 1:
      raise UserWarning('monitor could not be found or the specified name is not unique.')
      # Get the orientation
      monitor_type = sim.fdtd.getnamed(self.monitor_name, 'monitor type')
      if (monitor_type == 'Linear X') or (monitor_type == '2D X-normal'):
      orientation = 'x'
      elif (monitor_type == 'Linear Y') or (monitor_type == '2D Y-normal'):
      orientation = 'y'
      elif (monitor_type == 'Linear Z') or (monitor_type == '2D Z-normal'):
      orientation = 'z'
      else:
      raise UserWarning('monitor should be 2D or linear for a mode expansion to be meaningful.')
      monitor_pos = sim.fdtd.getnamed(self.monitor_name, orientation)
      if sim.fdtd.getnamednumber('FDTD') == 1:
      grid = sim.fdtd.getresult('FDTD', orientation)
      elif sim.fdtd.getnamednumber('varFDTD') == 1:
      grid = sim.fdtd.getresult('varFDTD', orientation)
      else:
      raise UserWarning('no FDTD or varFDTD solver object could be found.')
      ## Check if this is exactly aligned with the simulation mesh. It exactly aligns if we find a point
      ## along the grid which is no more than 'tol' away from the position
      tol = 1e-9
      dist_from_nearest_mesh_point = min(abs(grid-monitor_pos))
      if dist_from_nearest_mesh_point > tol:
      print('WARNING: The monitor "{}" is not aligned with the grid. Its distance to the nearest mesh point is {}. This can introduce small phase errors which sometimes result in inaccurate gradients.'.format(self.monitor_name,dist_from_nearest_mesh_point))
      @staticmethod
      def add_mode_expansion_monitor(sim, monitor_name, mode_expansion_monitor_name, mode):
      # modify existing DFT monitor
      if sim.fdtd.getnamednumber(monitor_name) != 1:
      sim.fdtd.setnamed(monitor_name, 'override global monitor settings', False)
      # append a mode expansion monitor to the existing DFT monitor
      if sim.fdtd.getnamednumber(mode_expansion_monitor_name) == 0:
      sim.fdtd.addmodeexpansion()
      sim.fdtd.set('name', mode_expansion_monitor_name)
      sim.fdtd.setexpansion(mode_expansion_monitor_name, monitor_name)
      sim.fdtd.setnamed(mode_expansion_monitor_name, 'auto update before analysis', True)
      sim.fdtd.setnamed(mode_expansion_monitor_name, 'override global monitor settings', False)
      # properties that must be synchronized
      props = ['monitor type']
      monitor_type = sim.fdtd.getnamed(monitor_name, 'monitor type')
      geo_props, normal = ModeMatch.cross_section_monitor_props(monitor_type)
      props.extend(geo_props)
      # synchronize properties
      for prop_name in props:
      prop_val = sim.fdtd.getnamed(monitor_name, prop_name)
      sim.fdtd.setnamed(mode_expansion_monitor_name, prop_name, prop_val)
      # select mode
      sim.fdtd.select(mode_expansion_monitor_name)
      ## If "mode" is an integer, it means that we want a 'user select' mode. Otherwise we try using it as a string directly
      if is_int(mode):
      sim.fdtd.setnamed(mode_expansion_monitor_name, 'mode selection', 'user select')
      sim.fdtd.updatemodes(mode)
      else:
      sim.fdtd.setnamed(mode_expansion_monitor_name, 'mode selection', mode)
      sim.fdtd.updatemodes()
      else:
      raise UserWarning('there is already a expansion monitor with the same name.')
      @staticmethod
      def cross_section_monitor_props(monitor_type):
      geometric_props = ['x', 'y', 'z']
      normal = ''
      if monitor_type == '2D X-normal':
      geometric_props.extend(['y span','z span'])
      normal = 'x'
      elif monitor_type == '2D Y-normal':
      geometric_props.extend(['x span','z span'])
      normal = 'y'
      elif monitor_type == '2D Z-normal':
      geometric_props.extend(['x span','y span'])
      normal = 'z'
      elif monitor_type == 'Linear X':
      geometric_props.append('x span')
      normal = 'y'
      elif monitor_type == 'Linear Y':
      geometric_props.append('y span')
      normal = 'x'
      elif monitor_type == 'Linear Z':
      geometric_props.append('z span')
      else:
      return geometric_props, normal
      def get_fom(self, sim):
      trans_coeff, self.wavelengths = ModeMatch.get_transmission_coefficient(sim, self.direction, self.monitor_name, self.mode_expansion_monitor_name)
      assert np.allclose(self.wavelengths, ModeMatch.get_wavelengths(sim))
      source_power = ModeMatch.get_source_power(sim, self.wavelengths)
      # Calculate the actual power |T|² / P_source (normalized)
      power_term = np.real(trans_coeff * trans_coeff.conj() / source_power)
      power_error = (power_term - self.target_fom **2 ) ** 2 # target_power=target_fom
      # self.T_fwd_vs_wavelength = np.real(trans_coeff * trans_coeff.conj() / source_power)
      # self.phase_prefactors = trans_coeff / 4.0 / source_power
      # Calculate the phase error term (∠T - target_phase)^2 (mapped to [-π, π])
      phase = np.angle(trans_coeff)
      phase_diff = phase - self.target_phase
      phase_diff = np.mod(phase_diff + np.pi, 2 * np.pi) - np.pi
      phase_error = phase_diff ** 2
      # Weighted combination of the figure of merit (FOM) (adjust the sign according to the optimization direction)
      self.T_fwd_vs_wavelength = (
      self.power_weight * power_error +
      self.phase_weight * phase_error
      fom = ModeMatch.fom_wavelength_integral(self.T_fwd_vs_wavelength, self.wavelengths, self.target_T_fwd, self.norm_p)
      return fom
      def get_adjoint_field_scaling(self, sim):
      # Obtain the transmission coefficient and wavelength from the original code
      # Power gradient term
      # grad_power = 2 * trans_coeff.conj() # when the FOM=max(power)
      grad_power = 2 * (np.real(trans_coeff * trans_coeff.conj() / source_power) - self.target_fom) * 2 * trans_coeff.conj()
      # Calculate the gradient of the phase term d( (∠T - θ)^2 )/dT = 2(∠T - θ) * (j/T*) and normalize it within the range of [-π, π]
      phase_diff = np.angle(trans_coeff) - self.target_phase
      grad_phase = 2 * phase_diff * (1j / trans_coeff.conj())
      # Combine gradient terms
      total_grad = 1/3 * (
      self.power_weight * grad_power +
      self.phase_weight * grad_phase
      omega = 2.0 * np.pi * sp.constants.speed_of_light / self.wavelengths
      adjoint_source_power = ModeMatch.get_source_power(sim, self.wavelengths)
      # Final scaling factor (verify the sign)
      scaling_factor = total_grad * omega * 1j / np.sqrt(adjoint_source_power)
      return scaling_factor
      @staticmethod
      def get_wavelengths(sim):
      return Wavelengths(sim.fdtd.getglobalsource('wavelength start'),
      sim.fdtd.getglobalsource('wavelength stop'),
      sim.fdtd.getglobalmonitor('frequency points')).asarray()
      @staticmethod
      def get_transmission_coefficient(sim, direction, monitor_name, mode_exp_monitor_name):
      mode_exp_result_name = 'expansion for ' + mode_exp_monitor_name
      if not sim.fdtd.haveresult(mode_exp_monitor_name, mode_exp_result_name):
      raise UserWarning('unable to calcualte mode expansion.')
      mode_exp_data_set = sim.fdtd.getresult(mode_exp_monitor_name, mode_exp_result_name)
      mode_exp_wl = mode_exp_data_set['lambda']
      fwd_trans_coeff = mode_exp_data_set['a'] * np.sqrt(mode_exp_data_set['N'].real)
      back_trans_coeff = mode_exp_data_set['b'] * np.sqrt(mode_exp_data_set['N'].real)
      if direction == 'Backward':
      fwd_trans_coeff, back_trans_coeff = back_trans_coeff, fwd_trans_coeff
      return fwd_trans_coeff.flatten(), mode_exp_wl.flatten()
      @staticmethod
      def get_source_power(sim, wavelengths):
      frequency = sp.constants.speed_of_light / wavelengths
      source_power = sim.fdtd.sourcepower(frequency)
      return np.asarray(source_power).flatten()
      @staticmethod
      def fom_wavelength_integral(T_fwd_vs_wavelength, wavelengths, target_T_fwd, norm_p):
      target_T_fwd_vs_wavelength = target_T_fwd(wavelengths).flatten()
      if len(wavelengths) > 1:
      wavelength_range = wavelengths.max() - wavelengths.min()
      assert wavelength_range > 0.0, "wavelength range must be positive."
      T_fwd_integrand = np.power(np.abs(target_T_fwd_vs_wavelength), norm_p) / wavelength_range
      const_term = np.power(np.trapz(y = T_fwd_integrand, x = wavelengths), 1.0 / norm_p)
      T_fwd_error = np.abs(T_fwd_vs_wavelength.flatten() - target_T_fwd_vs_wavelength)
      T_fwd_error_integrand = np.power(T_fwd_error, norm_p) / wavelength_range
      error_term = np.power(np.trapz(y = T_fwd_error_integrand, x = wavelengths), 1.0 / norm_p)
      fom = const_term - error_term
      else:
      fom = np.abs(target_T_fwd_vs_wavelength) - np.abs(T_fwd_vs_wavelength.flatten() - target_T_fwd_vs_wavelength)
      return fom.real
      @staticmethod
      def add_mode_source(sim, monitor_name, source_name, direction, mode, multi_freq_src):
      sim.fdtd.addmode()
      sim.fdtd.addmodesource()
      else:
      sim.fdtd.set('name', source_name)
      sim.fdtd.select(source_name)
      sim.fdtd.setnamed(source_name, 'injection axis', normal.lower() + '-axis')
      geo_props.remove('z')
      for prop_name in geo_props:
      sim.fdtd.setnamed(source_name, prop_name, prop_val)
      sim.fdtd.setnamed(source_name, 'override global source settings', False)
      sim.fdtd.setnamed(source_name, 'direction', direction)
      if sim.fdtd.haveproperty('multifrequency mode calculation'):
      sim.fdtd.setnamed(source_name, 'multifrequency mode calculation', multi_freq_src)
      if multi_freq_src:
      sim.fdtd.setnamed(source_name, 'frequency points', sim.fdtd.getglobalmonitor('frequency points'))
      if is_int(mode):
      sim.fdtd.setnamed(source_name, 'mode selection', 'user select')
      sim.fdtd.updatesourcemode(int(mode))
      else:
      sim.fdtd.setnamed(source_name, 'mode selection', mode)
      sim.fdtd.updatesourcemode()
      def fom_gradient_wavelength_integral(self, T_fwd_partial_derivs_vs_wl, wl):
      assert np.allclose(wl, self.wavelengths)
      return ModeMatch.fom_gradient_wavelength_integral_impl(self.T_fwd_vs_wavelength, T_fwd_partial_derivs_vs_wl, self.target_T_fwd(wl).flatten(), self.wavelengths, self.norm_p)
      def fom_gradient_wavelength_integral_on_cad(self, sim, grad_var_name, wl):
      target_T_fwd_vs_wavelength = self.target_T_fwd(wl).flatten()
      T_fwd_error = self.T_fwd_vs_wavelength - target_T_fwd_vs_wavelength
      if wl.size > 1:
      wavelength_range = wl.max() - wl.min()
      T_fwd_error_integrand = np.power(np.abs(T_fwd_error), self.norm_p) / wavelength_range
      const_factor = -1.0 * np.power(np.trapz(y = T_fwd_error_integrand, x = wl), 1.0 / self.norm_p - 1.0)
      integral_kernel = np.power(np.abs(T_fwd_error), self.norm_p - 1) * np.sign(T_fwd_error) / wavelength_range
      d = np.diff(wl)
      quad_weight = np.append(np.append(d[0], d[0:-1]+d[1:]),d[-1])/2 #< There is probably a more elegant way to do this
      v = const_factor * integral_kernel * quad_weight
      lumapi.putMatrix(sim.fdtd.handle, "wl_scaled_integral_kernel", v)
      sim.fdtd.eval(('dF_dp_s=size({0});'
      'dF_dp2 = reshape(permute({0},[3,2,1]),[dF_dp_s(3),dF_dp_s(2)*dF_dp_s(1)]);'
      'T_fwd_partial_derivs=real(mult(transpose(wl_scaled_integral_kernel),dF_dp2));').format(grad_var_name) )
      T_fwd_partial_derivs_on_cad = sim.fdtd.getv("T_fwd_partial_derivs")
      else:
      sim.fdtd.eval(('T_fwd_partial_derivs=real({0});').format(grad_var_name) )
      T_fwd_partial_derivs_on_cad*= -1.0 * np.sign(T_fwd_error)
      return T_fwd_partial_derivs_on_cad.flatten()
      @staticmethod
      def fom_gradient_wavelength_integral_impl(T_fwd_vs_wavelength, T_fwd_partial_derivs_vs_wl, target_T_fwd_vs_wavelength, wl, norm_p):
      if wl.size > 1:
      assert T_fwd_partial_derivs_vs_wl.shape[1] == wl.size
      T_fwd_error = T_fwd_vs_wavelength - target_T_fwd_vs_wavelength
      T_fwd_error_integrand = np.power(np.abs(T_fwd_error), norm_p) / wavelength_range
      const_factor = -1.0 * np.power(np.trapz(y = T_fwd_error_integrand, x = wl), 1.0 / norm_p - 1.0)
      integral_kernel = np.power(np.abs(T_fwd_error), norm_p - 1) * np.sign(T_fwd_error) / wavelength_range
      ## Implement the trapezoidal integration as a matrix-vector-product for performance reasons
      d = np.diff(wl)
      T_fwd_partial_derivs = T_fwd_partial_derivs_vs_wl.dot(v)
      ## This is the much slower (but possibly more readable) code
      # num_opt_param = T_fwd_partial_derivs_vs_wl.shape[0]
      # T_fwd_partial_derivs = np.zeros(num_opt_param, dtype = 'complex')
      # for i in range(num_opt_param):
      # T_fwd_partial_deriv = np.take(T_fwd_partial_derivs_vs_wl.transpose(), indices = i, axis = 1)
      # T_fwd_partial_derivs[i] = const_factor * np.trapz(y = integral_kernel * T_fwd_partial_deriv, x = wl)
      else:
      T_fwd_partial_derivs = -1.0 * np.sign(T_fwd_vs_wavelength - target_T_fwd_vs_wavelength) * T_fwd_partial_derivs_vs_wl.flatten()
      return T_fwd_partial_derivs.flatten().real
      The code for calling the modematch function is as follows:
      geometry = TopologyOptimization2D(params=params, eps_min=eps_bg, eps_max=eps_wg, x=x_pos, y=y_pos, z=0, filter_R=filter_R, beta=beta)
      ######## DEFINE FIGURE OF MERIT FOR EACH OUTPUT WAVEGUIDE ########
      fom1 = ModeMatch(
      monitor_name='fom_1', mode_number='Fundamental TE mode', direction='Forward',
      target_phase=0, power_weight=0.5, phase_weight=0.5, target_T_fwd = lambda wl: 1/3 * np.ones(wl.size),
      norm_p=2, target_fom=1/3)
      fom2 = ModeMatch(
      monitor_name='fom_2', mode_number='Fundamental TE mode', direction='Forward',
      target_phase=120, power_weight=0.5, phase_weight=0.5, target_T_fwd = lambda wl: 1/3 * np.ones(wl.size),
      fom3 = ModeMatch(
      monitor_name='fom_3', mode_number='Fundamental TE mode', direction='Forward',
      target_phase=240, power_weight=0.5, phase_weight=0.5, target_T_fwd = lambda wl: 1/3 * np.ones(wl.size),
      ######## DEFINE OPTIMIZATION ALGORITHM ########
      optimizer = ScipyOptimizers(max_iter=400, method='L-BFGS-B', pgtol=1e-6, ftol=1e-5, scale_initial_gradient_to=0.25)
      ######## DEFINE SETUP SCRIPT AND INDIVIDUAL OPTIMIZERS ########
      script1 = load_from_lsf('construct 2x3 MMI 6x6 rect input1.lsf')
      wavelengths1 = Wavelengths(start = 1550e-9, stop = 1550e-9, points = 1)
      opt1 = Optimization(base_script=script1, wavelengths = wavelengths1, fom=fom1, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=False, plot_history=False, store_all_simulations=False, save_global_index=True)
      wavelengths2 = Wavelengths(start = 1550e-9, stop = 1550e-9, points = 1)
      opt2 = Optimization(base_script=script1, wavelengths = wavelengths2, fom=fom2, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=False, plot_history=False, store_all_simulations=False, save_global_index=False)
      wavelengths3 = Wavelengths(start = 1550e-9, stop = 1550e-9, points = 1)
      opt3 = Optimization(base_script=script1, wavelengths = wavelengths3, fom=fom3, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=False, plot_history=False, store_all_simulations=False, save_global_index=False)
      wavelengths1 = Wavelengths(start=1550e-9, stop=1550e-9, points=1)
      ######## PUT EVERYTHING TOGETHER AND RUN ########
      opt = opt1+opt2+opt3
      opt.run(working_dir = working_dir)
    • Kirill
      Dear Subscriber,
      This topic appears to be a duplicate of Phase optimization of 2×3 MMI using Lumopt is ineffective. and will be closed.
      There is no need to post the same question twice.
      Thank you,
      Kirill
  • The topic ‘Phase optimization of 2×3 MMI using Lumopt is ineffective.’ is closed to new replies.
