October 19, 2019 at 3:07 pmvineethcnsSubscriber
Hello, we are trying to simulate the experimental work related to phase change of CO2 in a converging diverging nozzle mentioned in the paper "Characterization of Non-equilibrium Condensation of Supercritical Carbon Dioxide in a de Laval Nozzle" by Lettieri et al.
Can anybody suggest how to get convergence with respect to liquid mass fraction in the droplet based non-equilibrium compressible phase change solver in Ansys CFX?
The Settings are:
Residual target : 1e-4
Conservation target : 1e-3
Liquid Condensation rate relaxation factor : 0.3
Nucleation bulk tension factor : 1.0
Surface tension coefficient: 0.01
October 21, 2019 at 5:10 amDrAmineAnsys EmployeeCan you add more details? Have you check the NES tutorial?
October 21, 2019 at 1:48 pmvineethcnsSubscriber
Thank you very much dear Abenhadj for such a quick reply. Here are some of the details related to the CFX case
(1) We are using an axisymmetric domain for the nozzle (Nozzle boundary data from Lettieri et al. paper) with structured curvelinear mesh.
(2) We are starting from 55 bar initial pressure through the nozzle and slowly (in 2 milli second) increasing the pressure at inlet to 80 bar and decreasing the pressure at outlet to 28 bar.
Note: This way we are able to perfectly get convergence for the equilibrium solver case.
(3) The materials are defined using REFPROP based RGP tables. These tables work perfectly with the equilibrium solver.
(4) Transient solver setting details
 ANALYSIS TYPE
   Option = Transient
   EXTERNAL SOLVER COUPLING
     Option = None
   INITIAL TIME
     Option = Automatic with Value
     Time = 0
   TIME DURATION
     Option = Total Time
     Total Time = 0.01
   TIME STEPS
     First Update Time = 0.0
     Initial Timestep = 1e-08
     Option = Adaptive
     Timestep Update Frequency = 1
     TIMESTEP ADAPTION
       Courant Number = 0.1
       Maximum Timestep = 1e-07
       Minimum Timestep = 1e-9
       Option = MAX Courant Number
(5) Boundary conditions
   ===================Â
   DOMAIN Default Domain
   Domain Type = Fluid
   Location = fluid 1
   BOUNDARY inlet
     Boundary Type = INLET
     Location = inlet
     BOUNDARY CONDITIONS
       FLOW DIRECTION
         Option = Normal to Boundary Condition
       FLOW REGIME
         Option = Subsonic
       HEAT TRANSFER
         Option = Fluid Dependent
       MASS AND MOMENTUM
         Option = Total Pressure
         Relative Pressure = inletPressure
       TURBULENCE
         Option = Medium Intensity and Eddy Viscosity Ratio
     FLUID co2gas
       BOUNDARY CONDITIONS
         HEAT TRANSFER
           Option = Total Temperature
           Total Temperature = 311 [K]
         VOLUME FRACTION
           Option = Value
           Volume Fraction = 1.0
     FLUID co2liq
       BOUNDARY CONDITIONS
         DROPLET NUMBER
           Droplet Number = 0.0 [m^-3]
           Option = Specified Number
         VOLUME FRACTION
           Option = Value
           Volume Fraction = 0.0
   BOUNDARY outlet
     Boundary Type = OUTLET
     Coord Frame = Coord 0
     Location = outlet
     BOUNDARY CONDITIONS
       FLOW REGIME
         Option = Subsonic
       MASS AND MOMENTUM
         Option = Average Static Pressure
         Pressure Profile Bl = 0.05
         Relative Pressure = outletPressure
       PRESSURE AVERAGING
         Option = Average Over Whole Outlet
   BOUNDARY walls
     Boundary Type = WALL
     Location = walls
     BOUNDARY CONDITIONS
       HEAT TRANSFER
         Option = Adiabatic
       MASS AND MOMENTUM
         Option = No Slip Wall
       WALL ROUGHNESS
         Option = Smooth Wall
   BOUNDARY wedge0
     Boundary Type = SYMMETRY
     Location = wedge0
   BOUNDARY wedge1
     Location = wedge1
     REFERENCE PRESSURE
       Reference Pressure = 0 [bar]
(6) Multiphase solver settings
   MULTIPHASE MODELS
     Homogeneous Model = On
     FREE SURFACE MODEL
       Option = None
   FLUID DEFINITION co2gas
     Material = CO2v
     Option = Material Library
     MORPHOLOGY
       Option = Continuous Fluid
   FLUID DEFINITION co2liq
     Material = CO2l
     MORPHOLOGY
       Condensation Rate Relaxation Factor = 0.3
       Option = Droplets with Phase Change
     FLUID co2gas
       HEAT TRANSFER MODEL
         Include Viscous Work Term = On
         Option = Total Energy
     FLUID co2liq
       HEAT TRANSFER MODEL
         Option = Small Droplet Temperature
       NUCLEATION MODEL
         Nucleation Bulk Tension Factor = 1.0
         Option = Homogeneous
     HEAT TRANSFER MODEL
       Homogeneous Model = Off
       Option = Fluid Depent
     THERMAL RADIATION MODEL
       Option = None
     TURBULENCE MODEL
       Option = SST
     TURBULENT WALL FUNCTIONS
       Option = Automatic
   FLUID PAIR co2gas | co2liq
     Surface Tension Coefficient = 0.01 [N m^-1]
     INTERPHASE HEAT TRANSFER
       Option = Small Droplets
     INTERPHASE TRANSFER MODEL
       Option = Particle Model
     MASS TRANSFER
       Option = Phase Change
       PHASE CHANGE MODEL
(7) Initial conditions
   INITIALISATION
     Option = Automatic
     FLUID co2gas
       INITIAL CONDITIONS
         TEMPERATURE
         VOLUME FRACTION
     FLUID co2liq
       INITIAL CONDITIONS
         DROPLET NUMBER
           Droplet Number = 0 [m^-3]
         VOLUME FRACTION
     INITIAL CONDITIONS
       Velocity Type = Cartesian
       CARTESIAN VELOCITY COMPONENTS
         U = 0 [m s^-1]
         V = 0 [m s^-1]
         W = 0 [m s^-1]
       STATIC PRESSURE
         Relative Pressure = 55 [bar]
       TURBULENCE INITIAL CONDITIONS
( Miscellaneous settings
 SOLVER CONTROL
   Turbulence Numerics = First Order
   ADVECTION SCHEME
     Option = High Resolution
   COMPRESSIBILITY CONTROL
     Clip Pressure for Properties = On
     High Speed Numerics = On
     Minimum Pressure for Properties = 6 [bar]
     Total Pressure Option = Automatic
   CONVERGENCE CONTROL
     Maximum Number of Coefficient Loops = 100
     Minimum Number of Coefficient Loops = 1
     Timescale Control = Coefficient Loops
   CONVERGENCE CRITERIA
     Conservation Target = 0.001
     Residual Target = 1e-4
     Residual Type = RMS
   INTERPOLATION SCHEME
     Pressure Interpolation Type = Trilinear
     Shape Function Option = Geometric
     Velocity Interpolation Type = Trilinear
   MULTIPHASE CONTROL
     Volume Fraction Coupling = Coupled
   TEMPERATURE DAMPING
     Option = Automatic
   TRANSIENT SCHEME
     Option = First Order Backward Euler
   VELOCITY PRESSURE COUPLING:
     Rhie Chow Option = High Resolution
Once again, thanks Abenhadj for the help. Please let me know in case more details are required. -
October 21, 2019 at 2:32 pmDrAmineAnsys Employee
Quite hard to provide help here: You said you are able to get a converged result with the equilibrium model. Was that run unsteady too? Can you run the NEQ for a fixed operating point using the steady state solver to get a good initial guess?
October 21, 2019 at 5:49 pmvineethcnsSubscriberThe equilibrium solver was also run under unsteady analysis. The results achieved almost steady state.
The steady state data will provide initial condition for pressure, velocity, liquid and vapour mass fraction but not for droplet number, droplet diameter etc.
Anyway I will try that...I suspect that may cause divergence as the initial condition for droplet number and diameter are unknown. We will take them to be zero and that may be far from steady state value...
Thanks again Sir...We will come back to you... -
October 22, 2019 at 4:58 amDrAmineAnsys EmployeeThat is why to start with neq steady for operating point. You can assume at entrance no droplet like in the tutorial.
October 23, 2019 at 7:25 amvineethcnsSubscriber
Dear Abenhadj, Â
We tried the procedure as per your suggestions and we would like to thank you as we are getting better non-equilibrium condensation solver behaviour. However, there are still some issues which we would like you to guide us further. Please refer to the attached image:
1) We started with transient, equilibrium solver and then shifted to steady, equilibrium solver and got perfect convergence. Â
2) Then we used the results from the steady, equilibrium solver as the initial conditions for the non-equilibrium solver. Â
Things are converging but there are two issues: Â
(a) We occasionally get some spikes in the residual for the liquid mass fraction. The Maximum coefficient loops for the transient solver was 100 here. Â
My question here is that "Is this behaviour normal for this solver?"
(b) We decreased the Maximum coefficient loops to 40 to speed up the simulation but now the frequency of spikes increased. Â
My question is that how many coefficient loops we have to take? Are there any guidelines? Â
Thanks.
October 23, 2019 at 12:08 pmDrAmineAnsys Employee
I won't play with the number of the coefficient loops in transient run. Better to reduce the time step size and use default coefficient loop number.
November 5, 2019 at 11:56 amvineethcnsSubscriber
Dear Abenhadj
First of all thanks again for your continued support.
I have few more questions for you which I hope you will answer.
(1) For the non-equilibrium droplet based solver, We tried the adaptive time stepping control based on 'Number of Coefficient Loops' which were kept as minimum=1 and maximum=10. However, the time step taken by the solver was of the order of 1 nano second. It is really difficult to finish the simulation under such
a low time step.
 My question is: Is there a way to increase the time step? Will using second order Backward Euler for transient solution help in this case?
(2) I was going through similar work on CO2 condensation by Alireza Ameli et al. "Non-equilibrium condensation of supercritical carbon dioxide in a converging-diverging nozzle". They used a custom RGP file which had Spinodal limits built in for metastable regions. My question is that where I can get such an RGP file for CO2? Our University has Ansys Licence. Will the Ansys Customer support be able to help in this regard?
(3) My next question is: Does the non-equilibrium solver require custom RGP files with Spinodal limits built in for metastable regions?  Can we manage with just superheated and saturated data in the RGP table?
(4) My last question: In this formum once you discussed with somebody else about 'Subcooled Liquid' feature.
   Do we require the custom RGP file which had Spinodal limits built in for metastable regions for this feature to work?
Lastly: How can we acknowledge your help? Is there a way we can cite your help or Ansys?
Thank you very much again.
Regards -
November 5, 2019 at 1:44 pmDrAmineAnsys Employee
1/Probably: You might increase the courant number to a stable state. Regarding 2nd order for some quantities it is bounded scheme.
2/You can generate your RGP files using System Coupling (Earlier under AFD). Check the Fluent Beta Feature 2019R3.
3/Not obligatory
4/If not used, then CFX will assume saturated properties for the liquid even if the RGP contains both properties.
March 8, 2020 at 3:27 amssyadavSubscriber
Dear Abenhadj
Vineeth CNS was my student, thank you very much for guiding us so far. We are able to perform some simulations now but the solver diverges suddenly.
We found that gradually increasing the pressure at inlet and decreasing at the outlet from the mean initial pressure is the best way to proceed. The solver diverges when phase change starts some where in the nozzle.
I was going through the paper "Non-equilibrium condensation of supercritical carbon dioxide in a converging-diverging nozzle" by Alireza Ameli which mentions that
"The Gibbs free energy change of the vapor near the critical point is very small which leads the equation
to have an infinite value and causes error in the solver. In order to prevent this numerical instability, the
solver clips the critical radius to a certain amount, as a default 1 mm. This extremely large default
clipping value decreases the accuracy of the simulation and results in non-realistic droplet sizes. The
problem is that it is not possible to change or modify the formula in the Ansys CFX by the user. To
sidestep this problem, the critical radius was calculated according to the equation (1) in the post
processing stage. It was observed that the critical radius, see Figure 4, changes very moderately also in
the nucleation zone. Therefore, the radius of one nano meter has been estimated to be realistic for the
critical droplet size in this study and in the calculations the critical radius is clipped, by a CEL, to one
nano meter."
We are also trying to clip the critical radius but do not know the variable name in for Liquid CO2 critical radius.
Please help us again regarding how we can limit the critical radius of the liquid phase to say 1 nano meter using CEL expression.
Thanks again for the help.
Regards
March 9, 2020 at 4:32 amssyadavSubscriber
Dear AbenhadjÂ
The error message in the image above may give a clue regarding what may be happening.Â
It says: FATAL Bounds error detected
       Variable: Liquid CO2 specific heat capacity at constant pressure
We are using "subcooled liquid" in the material definition by enabling beta features and the RGP fileÂ
has the data corresponding to the subcooled region.
March 9, 2020 at 6:12 amDrAmineAnsys EmployeeI need to read the post and update later. I think there is way but want to double check
March 9, 2020 at 6:36 amDrAmineAnsys EmployeeAnd remember to contact the author of the paper for technical information
March 9, 2020 at 10:28 amDrAmineAnsys Employee
Provide a university mail address if you want to know how to limit the radius as it is supported.
March 11, 2020 at 7:02 amDrAmineAnsys Employee
Answered with expert parameter.
April 1, 2020 at 12:30 pmssyadavSubscriber
I hope you are safe from the ongoing pandemic and pray that you remain so.
 I am sorry I am bugging you again and again.
I am stuck at another step, this time related to how to incorporate spinodal data into the RGP tables.
I simulated two different fluid flows inside nozzles.
Case 1) Flow of water in Moses and Stein nozzle, Real Gas Data: IAPWS equation for water
Case 2) Flow of CO2 in another nozzle by Nakagwa, Real Gas Data: (a) RGP file for CO2 based on REFPROP, (b) Redlich Kwong EOS
I am following Ansys CFX guidelines which say that first switch off the nucleation process so that vapor super-cooling develops and then allow nucleation for the phase change process to occur.
The issue is: I am able to see significant water vapor super-cooling even after phase change in the nozzle with IAPWS data for water. Whereas, the super-cooling vanishes for CO2 once phase change starts. These happens with RGP files as well as with Redlich Kwong equation of state for CO2. The figures attached above show things more clearly.
Now the CFX manual says that IAPWS library extends to metastable regions.
I am writing my own RGP file generator based on REFPROP.
I have two questions:
1) How to force CFX solver to read metastable data for CO2 when using Redlich Kwong equation of state. Any expert parameter for it?
2) Where I can find more information on the spinodal data to be put in RGP files?
Thanks once again for all the help till now.
Regards
Shyam
April 9, 2020 at 6:27 pm
April 9, 2020 at 6:55 pmDrAmineAnsys EmployeeYou should activate beta features and use use subcooled liquid properties for RGP files. Next week available again for any feedback
April 9, 2020 at 6:56 pmDrAmineAnsys Employeeand refer to the documentation for creating RGP files out of REFPROP
April 11, 2020 at 5:38 amssyadavSubscriber
Thanks Amine for the response...
The option "RGP Liquid Properties = Subcooled" applies to RGP Tables.
I could not find this option for Real Gas Equation of state like the Redlich Kwong EOS.
I think there must be an expert parameter for this option while using Real Gas Equation.
Regards
April 14, 2020 at 12:30 pmDrAmineAnsys Employee
Yes that can be.
April 15, 2020 at 11:19 amDrAmineAnsys Employee
I cannot share the parameter here ( I know the parameter) and sincerely we think that a good RGP is enough to keep track of amlost everything. Cubic EOS are prone to errors for liquid calculations.
April 16, 2020 at 4:52 amssyadavSubscriber
Thanks dear Amine
The problem I am facing with RGP file is that the solver diverges randomly even with time step as low as 1.0e-9Â with errors mostly on 'fatal overflow in linear solver' and 'out of bound message for Cp'
It behaves well with Cubic equation of state and time step is also nice: 1.0e-7
That's why I wanted to know the parameter.
I am sorry I had to delete the post where I posted my mail id. I got a threat message from some hacker...
Best regards
April 16, 2020 at 8:37 amDrAmineAnsys Employee
I would recommend to write the RGP file with the described method in the documentation. Regarding the parameter I will share per mail but please that will be the second and last exception...
November 2, 2023 at 5:07 pmLeila EsfahanizadehSubscriber
I am engaged in a project, which involved simulating the discharge and dispersion of supercritical CO2 through the nozzles of a cutting tool.Â
The geometry comprises a nozzle with an approximate discharge diameter of 0.2 mm, an inlet boundary with supercritical CO2 at 90 bar and 311K, and an outlet at atmospheric conditions, where CO2 disperses into the air. The importance lies in the downstream conditions upon expansion, with a specific emphasis on solid CO2 volume fraction, CO2 mass fraction, and temperature distribution. Our simulation has thus far achieved convergence for equilibrium phase change modeling of CO2 discharge from the nozzle. We have utilized RGP tables for liquid CO2, vapor CO2, and saturation properties in their homogeneous binary mixtures. Furthermore, we've enabled Beta features in our simulations to account for subcooled liquid properties.
In the next step, for non-equilibrium phase change simulation, I also need to use the expert parameters discussed here. Could you please guide me on how I can manually control the critical radius of sub-cooled CO2 in the nucleation model, and an expert parameter for applying the RK equation of state to account for metastable states in the liquid phase?Â
I also appreciate any help regarding the modeling structure in which, I can include Air in addition to the CO2 equilibrium binary mixture in the phase change simulation.
Best regards,
Leila
- The topic ‘Phase change of CO2 in a converging diverging nozzle’ is closed to new replies.
- Convective Augmentation Factor in DEFINE_HEAT_FLUX
- Non-Premixed Combustion PDF generation with 4th-order interpolation
- ANSYS fluent – Rocky DEM coupling
- Conservation issue with a UDS solution
- Where is the Electrolyte Projected Area in the Reports tab of PEMFC Model?
- Solar load , Mesh Orientation and Beam direction
506
253
245
201
162
