April 5, 2024 at 7:15 pm
Newton Avila dos Santos
SubscriberI am trying to permanently connect a shell with an irregular shape (made of steel) to another rigid shell in LS-Dyna.
Can someone help me?I have tried different contact types, but did not manage to solve it.
ThanksÂ
April 8, 2024 at 12:43 pm
Alex Rycman
Ansys EmployeeHello,
Rigid bodies cannot be included in a constraint-based contact, only tied contacts that are penalty based can be used with rigid bodies.
You could use *CONSTRAINED_EXTRA_NODES_OPTION that will allow you to constrain an edge of a shell (made of metal) to the rigid shell in your model.
Please let me know how it goes.
Thank you,
Alex
April 14, 2024 at 1:41 pm
SubscriberHello Alex,
Thanks for your answer.
I will try it and let you know what happened.
Br,
Newton
- The topic ‘Permanent connection between steel and rigid shells’ is closed to new replies.
