June 19, 2020 at 4:06 pm
divydesh
SubscriberHi,
I'm trying to simulate peripheral milling operation in explicit dynamics in ansys. I want to rotate the cutter and move it simultaneously along the length of the workpiece. However, I'm unable to do both. I'm not sure about what type of conditions I should use. I also don't want the cutter to deform, so what condition should I give? I'm also attaching some images of what I've been doing till now.
These are the contact settings I'm using
As I was unable to move the cutter in x-direction. I gave displacement to workpiece instead. The above image shows that.
These are the settings I'm using for rotation of cutter. But when I solve, its cause the cutter to move randomly in the xy plane and not stay at its place only rotating.
Please help me, its urgent for my project
June 19, 2020 at 4:45 pm
peteroznewman
SubscriberI suggest you rotate the cutter on a fixed axis and move the work piece toward the cutter.
June 19, 2020 at 5:18 pm
divydesh
Subscriberwhich condition should i give for cutter rotation - displacement or remote displacement?
and is the condition given for workpiece to move is correct?
June 20, 2020 at 2:34 pm
divydesh
SubscriberI tried your suggestion. It's still not working. Can you please tell me the detailed boundary conditions and body connections that I should use for it to work.
June 20, 2020 at 4:57 pm
peteroznewman
SubscriberUnder the Connections folder, insert a Revolute Joint to ground on inner diameter face of the cutter. Add a Joint Load of Rotational Velocity to that joint.
Insert a Translation Joint to ground on the back face of the work piece. Add a Joint Load of Translational Velocity to that joint.
- The topic ‘Peripheral Milling in Explicit Dynamics’ is closed to new replies.
5639
1885
1403
1303
