July 11, 2024 at 7:20 am
July 11, 2024 at 9:39 am
Forum ModeratorIt depends. Do you expect to see swirl in the system?
July 11, 2024 at 2:44 pm
Zwernjayden
SubscriberI am going to guess no
July 12, 2024 at 10:25 am
Forum ModeratorIf there's no swirl I'd expect cyclic and symmetric to give much the same result. If there's swirl you'll need cyclic/rotational periodics. Note, if you're only seeing 4 repeats check in the Views panel as you've not set enough copies.Â
- The topic ‘Periodic vs Cyclic vs Symmetric’ is closed to new replies.
