September 7, 2022 at 1:35 pm
Kin Wing Wong
SubscriberHello,
We are interested to perform LES calculations on rotating discs with complicated internal stator structures. To do this, we would like to avoid simulating the whole domain but simulating only a wedge. We are using Fluent Meshing to create the rotating and stationary zones for the geometry and applied shared faces in the workbench in SpaceClaim.
In Fluent Meshing, we applied the rotational periodic boundary to the two azimuthal sides of the domain. We also defined two interfaces for the connecting surfaces between the rotating domain and the stationary domain in spaceclaim. This is working for the MRF case and it is also possible for me to simulate a sliding mesh rotating simulation with the whole geometry.
However, when I make a wedge from the whole geometry and follow the same procedure. I cannot use the periodic repeat function, since there are no interfaces being recognized in Fluent. What should I do to circumvent this problem? Is there any special settings that I need to do in Spaceclaim when I create the geometry?
September 15, 2022 at 9:09 am
SVV
Ansys EmployeeHi,
Can you share a picture of the geometry?
September 15, 2022 at 9:19 am
September 15, 2022 at 10:11 am
SVV
Ansys EmployeeCan you please go through the following tutorial : Axial Fan – Ansys Fluent Meshing Watertight Geometry Workflow - YouTube
September 15, 2022 at 11:01 am
Kin Wing Wong
SubscriberThere is nothing new in this video. I am following the same procedure to prepare a MRF simulation, and it works. So, there is no problem here.
My question in on the sliding mesh simulation, and I need a periodic repeat function for the surface between the rotational and stationary. When the rotationg mesh rotates, it will have occasion where the interface is only partial overlapping with the stationary mesh. For the surface without overlapping, the periodic repeat should copy the values of the interface to the non-overlapping face.
It is avialable in the sliding mesh tutorial, however, there is no tutorial on how to prepare the geometry. If I follow the video to construct the geometry, you will end up with no interface boundary. So, you cannot activiate the periodic repeat function.
September 15, 2022 at 11:28 am
Kin Wing Wong
SubscriberOk, I just figure out. I have to set define/mesh-interfaces/one-to-one-pairing? yes. and then I can set the interface to periodic repeat. It is still not working with divergence of the velocity, but I think I will figure it out.
- The topic ‘Periodic Repeat for Sliding Mesh LES’ is closed to new replies.
5939
1307
