December 1, 2023 at 9:33 am
davide.dipasquale
SubscriberI have followed the tutorial on ANSYS Learning (
&t=4s) to understand how set up Periodic BCs, but it does not work for my case.
I have a 2 blades wind turbine and I want to set up a Periodic BC with an angle of 180 deg in order to simulate only 1 blade, but when I switch to fluent I have 2 separate Peridoic BCs instead of only one. Any suggestions? -
December 1, 2023 at 2:25 pm
Federico
Ansys EmployeeHello,Â
can you show some screenshots of what you are seeing?
December 5, 2023 at 10:14 am
December 5, 2023 at 1:20 pm
December 5, 2023 at 2:19 pm
December 7, 2023 at 10:06 am
davide.dipasquale
SubscriberI do not have any shadow face
December 7, 2023 at 2:11 pm
Federico
Ansys EmployeeYou do not have conformal mesh between both periodic faces. But they are still periodic.
December 8, 2023 at 11:30 am
davide.dipasquale
SubscriberSorry but I do not understand my mesh is conformal:
"Periodicity has been defined for blade10.3_nacelleddp_v15-blade10.3_nacelleddp_v15-fluid, and the mesh are now matching between the reference side (yellow) and the periodic side."
I should I have a single periodic BC?
December 8, 2023 at 1:40 pm
Federico
Ansys EmployeeSorry, the display that I showed was for 23R2. It seems that 22R2 does not show the shadow zone in the GUI. Forget my post about conformal interface.
Maybe I misunderstood your question. You should have 2 separate periodic BCs in the Fluent Boundary panel. Basically, what comes in/out of one periodic BC will be communicated to the second periodic BC, and vice versa.
December 13, 2023 at 10:57 am
- The topic ‘Periodic boundary Conditions in Fluent Meshing’ is closed to new replies.
5804
