November 27, 2024 at 6:31 pm
scabo
SubscriberHi
I am trying to simulate air-water flow in a straight pipe with periodic left and right boundaries with Volume of Fluid. After making the boundaries periodic, there is no option to specify mass flow rate, only pressure gradient option is there. I want to specify the mass flow rate at the inlet. How will I initialise the problem? Will it be through normal Initialisation? I am slightly confused-any help is greatly appreciated..thanks!
AB
November 28, 2024 at 10:27 am
Forum ModeratorHave a look in the documentation - there's a section on limitations.Â
November 28, 2024 at 1:37 pm
scabo
SubscriberHi documentation means user guide right which is available online?
November 28, 2024 at 1:38 pm
scabo
SubscriberÂ
https://www.#######/project/neptunius/docs/fluent/html/ug/node252.htm
this one??
November 28, 2024 at 1:48 pm
Forum ModeratorNot the third party and very out of date one, no. If you click on Help in the solver you'll get the current set. Or  Public Ansys Help tends to work equally well.Â
November 28, 2024 at 3:01 pm
scabo
SubscriberThis is the one https://ansyshelp.ansys.com/public/account/secured?returnurl=//Views/Secured/corp/v242/en/flu_ug/flu_ug_sec_periodic.html?q=periodic%20boundary%20conditions%20fluent
Here it is written multiphase flow can be modeled, that means i can use VOF models also right?
November 28, 2024 at 3:12 pm
Forum ModeratorCorrect, but read that line carefully relative to your original question.Â
November 28, 2024 at 3:18 pm
scabo
SubscriberYes i can only use a pressure gradient with VoF. Then will i just hybrid initialise? Because in standard initialisation we have to provide velocities which are not known on the periodic face..
November 28, 2024 at 3:27 pm
Forum ModeratorNo, you need to use standard. Then patch the liquid. Do NOT patch a non 1 or 0 volume fraction of phase: read the VOF model approach to see why.Â
November 29, 2024 at 2:49 pm
scabo
SubscriberHi, What is meant by your line: Do NOT patch a non 1 or 0 volume fraction of phase. Does that mean i should only patch a surface with volume fraction of either 1 or 0?
November 29, 2024 at 2:57 pm
Forum ModeratorCell zone, but yes VOF needs to be 1 or 0 as it's an interface tracking model. Eulerian/Mixture are fine with values between zero and one depending on other factors.Â
November 30, 2024 at 6:39 pm
scabo
SubscriberHi, I have checked, after standard initialisation i have applied patch and selected volume fraction>air=0 on the periodic face. It is correct right?
November 30, 2024 at 10:20 pm
scabo
SubscriberAlso, i have left the standard initialise panel as it is without giving any X, Y velocities-just initialised and applied the patch..i hope it is fine?
December 3, 2024 at 1:42 pm
Forum ModeratorYou need to patch into the cell (volume) zone.Â
December 3, 2024 at 4:23 pm
scabo
SubscriberI created a region through cell register and then patched water into it after initialisation. Is that correct?
December 3, 2024 at 4:31 pm
Forum ModeratorYes, assuming the patched region gives you the correct liquid volume in the domain.Â
December 3, 2024 at 4:50 pm
scabo
SubscriberThanks-I will solve and see what happens
December 3, 2024 at 4:59 pm
scabo
SubscriberBut one thing is there: i have specified pressure gradient on the periodic faces and then created a 3D region near the periodic face and patched it with water. So the pressure gradient is not acting on the water right? but instead it is acting on the inlet face. but still i am getting movement of water in the results.
December 3, 2024 at 5:01 pm
Forum ModeratorI'd patch to a set depth rather than from a boundary. Pressure drop is for the domain, it's not phase related.Â
December 3, 2024 at 5:17 pm
December 4, 2024 at 10:03 am
Forum ModeratorIt'll work, but take time to find a peridic flow level. I'd generally patch so the liquid is in about the right place - ie start as near to the expected solution as possible.Â
December 4, 2024 at 4:06 pm
scabo
Subscriberokay thanks
December 5, 2024 at 2:49 am
scabo
SubscriberI was just asking after standard initialisation i do not need to provide any X,Y velocities right? just patch and apply a pressure gradient on the periodic face..
December 5, 2024 at 2:00 pm
Forum ModeratorYou don't. However, the better the initialisation data the more stable the solution. For a transient that also means a faster overall solution as it takes less time to reach equilibrium.Â
January 14, 2025 at 3:24 pm
scabo
SubscriberHi
I successfully applied Periodic BC in Volume of Fluid in Fluent, but the the pressure gradient is driving the air phase to a veryy high speed and therefore there are some waves on the water surface. Is there any way to get rid of this; like applying the pressure gradient only to the water phase and will this type of fix actually work? My initial water patch is just a flat bed of water of some depth inside the length of the cylinder shown above in previous replies.
thanksÂ
January 14, 2025 at 4:04 pm
Forum ModeratorDoesn't look like it. However, if there are no waves why do you need to model the free surface?Â
January 14, 2025 at 4:24 pm
scabo
SubscriberI want a stable free surface because i wanted to visualise the secondary currents in the water region in an air-water system. Secondary currents are cross-section phenomenon which are correctly visualised when we have a stable free surface. When i modeled a full pipe of very long length with VoF modeling with normal velocity inlet of water i am getting correct results but needed to save computational time so planned to use a periodic BC in VoF.
January 14, 2025 at 4:25 pm
scabo
SubscriberCan i use some UDF to apply the pressure gradient only in the water region? That may solve the problem? or something like that
January 14, 2025 at 5:06 pm
Forum ModeratorNot easily. The periodic condition is old, and was made to allow repeated sections to be modelled cheaply. It works for VOF simply because nothing causes it to break.Â
January 14, 2025 at 5:17 pm
scabo
Subscriberthanks-"but what do you mean by nothing causes it to break"
January 14, 2025 at 5:29 pm
Forum ModeratorIt means just that. VOF works with periodics because it doesn't break any of the solver routines. There aren't any extra functions for VOF in periodic flows.Â
January 14, 2025 at 5:49 pm
scabo
SubscriberOkay
January 14, 2025 at 9:23 pm
scabo
SubscriberSo you are saying that there are some limitations of using Periodic BC in VoF models?
January 15, 2025 at 9:40 am
Forum ModeratorOnly what's covered in the manual. If you want a different pressure drop for each phase that implies a different flow rate, and is that then periodic?Â
January 15, 2025 at 9:02 pm
scabo
Subscriber -
January 16, 2025 at 3:46 pm
Forum ModeratorNot necessarily as I suspect it'll try and set up a standing wave. Have a look at the Baker Chart for flow regimes.Â
January 16, 2025 at 4:15 pm
scabo
SubscriberYes it is creating a wave because air vel is higher. Can i give the pressure gradient in proportion to the volume fraction somehow?Â
January 16, 2025 at 5:08 pm
Forum ModeratorI don't think so.Â
5719
