May 3, 2025 at 4:45 pm
Miladfarahi957
SubscriberI have heat transfer problem.
My geometry is periodic in the y direction (Translational) and the top curved face is a wall. while the other sides have symmetry boundary conditions.
My question is that does defining a periodic boundary condition ( mass flow rate) means that the flow is considered fully developed?
if not how am I supposed to define it as there are no option to choose the mass flow rate as udf or expression?
Additional Information & Question:
I did the simulation with the following boundary conditions:The following are the results I got after the simulation:
Periodic Condition-After- Simulation
Bulk-Temp.Â
Temp countor on wall:
My BC is static wall temp.! why does BC looks like this. why is it changing. and max temp in my simulation is 50. why do I have 52.6 here?
I don't understand the problem.
Please help. -
May 4, 2025 at 8:34 pm
scabo
SubscriberI can tell that if u use periodic BC then it means fully developed flow-i also use the periodic BC along a pipe and i get fully developed flow, but i have no temperature equations.
May 5, 2025 at 8:57 am
Miladfarahi957
SubscriberThank you. that helps.
3024
971
857
830
777
