Penetration simulation using ANSYS/explicit dynamic
    • dal88236
      Hi all,
      I am trying to do a simulation of a sharp needle penetrating the other material using ANSYS WB 19.2 explicit. The simulation is displacement controlled as the needle keeps going down in a certain rate and penetrates the material. According to the literature I found, the failure criterion should be von-mises stress criterion. As the equivalent stress in the element exceeds a specific value, the element will be deleted and the tip continue to go deeper.
      My question is that since the failure criteria I can choose in explicit seem not include VM stress criteria, how can I perform this simulation based on VM criteria. Or there is already a model can be chosen?
      Any help will be appreciated!
    • Vahidebrahimi
      Hi mate
      I introduced failure strain criterion that is between 10-25% to remove elements as penetrating. If you are not asked to use von Mises criterion, you can have a look at the principal failure strain of skin.
      I am also using explicit dynamics and want to measure the insertion force in time, do you know how I can measure insertion force - time. I am displacing the needle from the end to penetrate using Tabular displacement. In the available results, there is no Force components ! and I am trying to measure the force from the needle back (where the displacement is introduced).???
      Also, can you tell me what is your "End time" ? cause if I select my end time to be 3 sec. It will take ages to finish. So, I had to change it to smaller value of end times 1e-3. This end time is not realistic as my real end time based on needle movement should be 3 sec. Do you have any idea for my case???
      Kind Regards
  • The topic ‘Penetration simulation using ANSYS/explicit dynamic’ is closed to new replies.
