May 9, 2021 at 10:28 am
info
SubscriberCould you please recommend a PDM software for Spaceclaim?
May 10, 2021 at 4:59 am
Charudatta Bandgar
SubscriberLet me check Evangelos Papageorgiou
Regards.
May 17, 2021 at 3:14 pm
info
SubscriberCharudatta Bandgar I was wondering if the sharepoint still works for 2021 R1 version. It was a basic pdm solution that came free with Spaceclaim 2012.
May 17, 2021 at 12:42 pm
Bengt Dahlborg
SubscriberHighstage has a cloud based PDM solution that works with SpaceClaim. for more information contact info@cadtools.se
May 17, 2021 at 3:11 pm
info
SubscriberBengt Dahlborg Thanks for the info. Is there a starting cost?
May 17, 2021 at 5:39 pm
Bengt Dahlborg
SubscriberEvangelos Papageorgiou  Yes, it's a cost to the system.
Send an email to info@cadtools.se for more information about the different features ,installation options and prices.
May 17, 2021 at 8:48 pm
Luca Di Rosa
SubscriberHi Evangelos Papageorgiou
I am searching a PDM for Spaceclaim (and Rhino) as well.
I had a talk already with Highstage but have not evaluated yet.
I found other solution as well, listed below in no particular order.
Does anybody have experience and can share some feedback? thanks!
May 18, 2021 at 7:34 am
info
SubscriberLuca Thanks for the update.
There is one more called YaPLM today.
I am considering this. Looks easy.
May 18, 2021 at 7:48 am
Luca Di Rosa
SubscriberEvangelos Papageorgiou thanks about this, I did quite some research but did not heard of YaPLM, will add to the list!
May 19, 2021 at 6:20 am
May 18, 2021 at 7:20 am
Charudatta Bandgar
SubscriberThanks for the help Bengt Dahlborg Evangelos PapageorgiouÂ
I will get some information regarding this and will get back to you, Luca
Regards.
November 10, 2021 at 9:32 pm
Luca Di Rosa
SubscriberHi Charudatta Bandgar
any news about this?
I am working since some time now with Grabcad Workbench, very basic but free. I am happy about it but would investigate an option with some more control.
The list looks the same as above, apart from Kenesto which look dead, any response from them since weeks.
Evangelos Papageorgiou did you tried YaPLM?
November 13, 2021 at 8:59 am
info
SubscriberI did not try it because the cost is high for us.
I was looking for something to start with. It would be easy to work with Sharepoint as it is already installed in Office365.
November 17, 2021 at 11:14 pm
Luca Di Rosa
I got an offer from YaPLM and the cost looks quite high for me too.
I have any experience with Sharepoint. I actually should have too in my Office but i can not find it.
I do suggest you to give a try in the meantime with Grabcad workbench. It is basic but free and I did not experienced any issue yet.
November 18, 2021 at 4:48 am
info
SubscriberLuca Could you please provide me with guidelines how to setup Grabcad to my pc at home.
I would like to try first with my personal stuff and see if I can use it at work.
Thanks again for the info.
November 18, 2021 at 12:39 pm
Luca Di Rosa
SubscriberEvangelos PapageorgiouÂ
Setting up GC is quite easy, just install the client and let it do the sync job for you as you trigger it. Alternatively you can also do it manually trough the web interface.
Better than my help please have a look here where you can find clear setup and use instructions from GC.
I am sorry to update about Kenesto as well. Finally I got a response from them reactivating my trial account to do some test. It is still buggy: Rhino files can not be saved and syncing Spaceclaim files cause the computer to freeze.
I am sorry about this because it was looking like a good Cloud PDM but it just does not works!
November 19, 2021 at 4:53 am
info
SubscriberLuca Thanks for the help.
I will give it a try.
- The topic ‘PDM for Spaceclaim’ is closed to new replies.
