Pdf_XY and Pdf_Yi
    • Jeroen
      I am trying to get the species mass and molar fractions for my continuous gas phase into a UDF for DEFINE_DPM_HEAT_MASS(). According to the manual, this can be done by using the following.
      Pdf_Yi(c, t, n) or Pdf_XY(c,t,x,y)
      In order to use these expressions "pdf_props.h" must be included. Hooking the UDF causes no issues, however upon running my model the simulation crashes when reaching the DPM Iteration. More specifically: it crashes because of these functions.
      I am using Fluent version 19.3. Is there any other way to get these fractions for a species transport model? Or how do i resolve this issue?
      Kind regards,
      Jeroen
    • DrAmine
      Are you working with pdf based combustion model or just using species model?
    • Jeroen
      Im am just using a species model, no combustion involved here
      Then have a look for the species macros, the pdf ones you're using relate to a combustion model.
    • Jeroen
      I got it to work by using c->yi[ns]
      previously this did not work because there was an error in my cphase_state_t variable, it should have been:
      cphase_state_t *c = &(tp->cphase[0]);
      Thanks for your help
    • DrAmine
      The example in the manual does cover it.
Viewing 5 reply threads
  • The topic ‘Pdf_XY and Pdf_Yi’ is closed to new replies.
