November 4, 2025 at 9:17 am
November 4, 2025 at 11:44 pm
Takeshi Itadani
Ansys EmployeeTo import ODB++ data, you need solver licenses (elec_solve_level1 and elec_solve_level2) as shown in the message. Is it possible that someone else is running an analysis and using the solver licenses?
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
