September 9, 2021 at 12:29 pm
Dheeraj_Singh
Subscriber -
September 9, 2021 at 2:03 pm
Subashni Ravichandran
Forum ModeratorHello Dheeraj Singh
If, in your model, there is any face that is in contact with both Fluid and Solid faces, please use the imprint tool between the solid faces .Â
You may find a similar tutorial on the Getting started- Thermal tutorials page.There are some CHT examples on the Getting started - Fluids tutorials page as well.
September 9, 2021 at 5:03 pm
Dheeraj_Singh
SubscriberHello Subashni
Thanks for your response.Â
I have gone through all tutorials.Â
But this imprint feature doesn't work between enclosure(fluid domain) and solid(heat sink, heat source). This imprint feature works only for solid - solid(between heat source and heat sink).Â
In my work, forced convection happens due to air flow over PCB(heat source, heat sink). Can you please share this kind of sample models or tutorials.
If possible we can discuss this over call.
Dheeraj
September 13, 2021 at 11:36 am
Forum ModeratorDheeraj SinghÂ
The same example that you require of a PCB is in this page.
It is performed as a Thermal simulation and not CHT.
Check out the third video in the Player.
Getting Started - Thermal - Discovery Getting Started - Ansys Discovery Forum
September 13, 2021 at 11:20 am
Dheeraj_Singh
Could you please provide update on this.
Thanks in advance.
September 13, 2021 at 11:38 am
If that example is not clear to you we can discuss this over Teams call at 11AM tomorrow (14th Sept).
Please let me know your availability so that I can send you the Teams meeting link
September 13, 2021 at 12:07 pm
Dheeraj_Singh
Please share teams meeting invite for call at 11AM (14th Sept).
Dheeraj
September 13, 2021 at 12:21 pm
I have shared the invite via email.
- The topic ‘PCB cooling simulation’ is closed to new replies.
5709
