April 12, 2024 at 9:55 pm
YH
SubscriberHello,
I calculated branced pipe flow. I used k-epsilon model because I wanna initialize the model for LES. I injected water and apply pipe wall friction. Gravity is not considered. I have some qeustions.
1, continuity and epsilon does not converge and cannot be lower than 1e-6. I think it is because of the mesh, could you give me some advice what mesh should I apply?Â
2, I found bumps on the wall when I see velocity pathline, is this due to wall friction?
April 15, 2024 at 10:47 am
Forum ModeratorPlease review the training materials in Learning re convergence.Â
Looking at the above, please plot a velocity contour on the centre line plane with node values off and post the results here.Â
- The topic ‘pathline of velocity magnitude’ is closed to new replies.
Ansys Innovation Space
1057
1051
965
942
