October 3, 2021 at 1:20 pmJohnathan_Lee SubscriberDear Community, I have encountered a problem with DPM processing. I am doing an unsteady particle track in the transient model. One problem is that for the unsteady track, the pathlines of particles can not be displayed which is applicable in steady track. But I need to show the pathlines in my report, and it is significant to me. If anyone has a clue, appreciate it so so much! Thanks in advance! :) October 3, 2021 at 2:45 pmai0013 SubscriberAs you may know, in steady DPM tracking you can vary the -number of tries-, which will calculate and display the possible trajectories to be followed by a particle. Each trajectory calculation includes a new stochastic representation of the turbulent contributions to the trajectory. Since these calculations depend on a steady assumption, the force balance acting on a particle is recalculated for every try.
 Contrarily, in unsteady DPM tracking the -number of tries- is equal to 1. Here the particle trajectory is evolved step-by-step and depends on the instanteous features of the flow. Hence you cannot display pathlines since the flow doesn't know yet what will occur in the next time steps. You can only display current positions. I believe you will need to reconstruct particle trajectories manually.
 What I suggest is to do:
 If you have an open system, keep the original injection and let flow to develop normally and establish some few FTT.
 Create point injections, keep your particle properties but give a small mass relative to your DPM flow rate. These will act as particle tracers
 Define the export settings for these tracers (save local copies of the .his files). These usually contain the particle position, rho, d, mass, T, etc... The higher the saving frequency, the more resolution you'll give to the trajectory
 Reconstruct the trajectories based on (x,yz,) positions. Maybe use Matlab
 October 4, 2021 at 11:41 amJohnathan_Lee SubscriberThanks, Alainslas! Really appreciate it!
 Viewing 2 reply threads- The topic ‘Pathline of unsteady particle tracking in DPM’ is closed to new replies.
 Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
 Top Contributors-
                        4167
                        1487
                        1363
                        1189
 Top Rated Tags© 2025 Copyright ANSYS, Inc. All rights reserved. Ansys does not support the usage of unauthorized Ansys software. Please visit www.ansys.com to obtain an official distribution.
              Ansys Assistant
          Welcome to Ansys Assistant!
RETRY You are navigating away from the AIS Discovery experience
