September 29, 2021 at 10:02 am
dhaya400
SubscriberHi,
I am running a transient flow simulation in Ansys Fluent. I have been running the simulation for 10 cycles to get convergence.
After that, I am enabling passive scalar transport to know the concentration of scalar at different outlets.
My question: How many cycles I have to run the simulation, after enabling passive scalar model to get converged solution?
with regards,
DK
September 29, 2021 at 11:42 amKarthik Remella
AdministratorHello When you say cycles, are you referring to iterations or time-steps? If you are referring to iterations per time-step, you may want to make sure that your residuals go down by at least 3 orders of magnitude. The actual number depends on the choice of time-step, the velocity scales, and the mesh size.
Karthik
September 29, 2021 at 3:23 pmdhaya400
Hi
Here the cycle refers to input sinusoidal wave for a period of 1s. So 10 cycles refers to total time of 10s.
Would you please clarify now?
with regards DK
September 30, 2021 at 1:38 pmRob
Forum ModeratorIf it's a pulse it's until not much is coming out. If the scalar is always on it's until the result is showing a "constant" value or cycle. You'll have an idea of the flow residence time, so it's usually a function of a few times that.
Viewing 3 reply threads- The topic ‘Passive scalar transport model’ is closed to new replies.
5669
1890
1419
1304
