June 10, 2025 at 1:49 am
z5132453
SubscriberHi all,Â
I am simulating alloy remelting process with alloy element evaporation. I would like to use solidification and melting model to describe the mushy zone. I define alloy as solvent and another alloy element as solute as a mixutre with using the species model. then I have following questions :
- where to set up the partition coefficient Ki, I cannot find it in GUI?
- where to set up the Eutectic mass fraction for each of component? i cannot find it in either materials for each fluid or for mixture.
- if my alloy does not have a specific eutectic temperature, can the solidus temperature of solvent be appromatiely used as eutectic temperture?
any answer will be great help.
Thanks in advance!
Jackson
June 10, 2025 at 3:47 pm
Forum ModeratorYou may want to read  https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/flu_th/flu_th_chp_melt_freeze.html The model isn't overly intelligent so if the alloy results in "odd" material properties you may need to use a UDF or rethink the approach.Â
Ansys Innovation Space
1057
1051
896
887
