July 20, 2024 at 8:43 am
Eleftherios Marinelis
SubscriberHello all!
I am simulating hail and rain over an airfoil. I am at this point:
I need some help because i want to visualize my simulation like this:Â
Meaning I want the red dots that you can see at the left in the first photo to "hit" the airfoil in order to check the results.
Maybe do you know what is wrong? Should I run for a langer time to get this result?
Thank you!
July 22, 2024 at 7:32 am
SubscriberHello! Can anyone help me?
July 22, 2024 at 10:58 am
Forum ModeratorHave you checked  https://innovationspace.ansys.com/forum/forums/topic/patricle-track/ for info?Â
July 22, 2024 at 11:04 am
SubscriberYes of course I did check that. The only thing basically that I want is the raindrops to hit the airfoil with their inital diameter. As you can seef romt he moment that the calculation starts the diameter is decreasing.
July 22, 2024 at 12:24 pm
Forum ModeratorAnd why post a new thread? Diameter will change if you set models accordingly, so, what did you set? What did you learn from the tutorials?Â
July 22, 2024 at 12:40 pm
July 23, 2024 at 10:55 am
Forum ModeratorThe diameter will change with those settings. Look in Help, and tell me why you selected each of those Physical Models.Â
- The topic ‘Particles simulation’ is closed to new replies.
5649
1885
1404
1303
