July 8, 2024 at 4:10 pm
wayne.gao
SubscriberI ran Fluent-Rocky 2-way coupling with Eulerian multiphase in Fluent, particle phase volume fraction is always 0. But i can see particle is moving into fluid in Rocky, which means particle volume fraction should be non-zero because of particle. How can i get particle phase volume fraction?
July 9, 2024 at 11:13 am
Forum ModeratorCheck how the coupling is set up as Rocky may be passing the volume fraction back as a flow resistance and you should be looking in the UDMs for volume fraction.Â
July 26, 2024 at 9:29 am
wayne.gao
SubscriberThank you for your reply. I found that because ROCKY will copy FLUENT CAS FILE to their own folder and save data there, and need some work to find.
Embbed coupling by Rocky have no UDM to use.
- The topic ‘particle phase volume fraction problem with Fluent-Rocky coupling’ is closed to new replies.
1675
1386
1248
