May 21, 2024 at 9:10 pm
kiran.purushothamakeshavan
SubscriberHey,
I'm calculating a quantity called the Tabor number, which I need for my simulation setup. For this I would need particle overlap measurement. I went through the technical manual but I only see the force vs overlap plot.Â
Is there a way to calculate overlap between particles and material?
Thanks,
Kiran -
July 15, 2024 at 12:07 pm
Lucas Bertollo Baggio
Ansys EmployeeHello Kiran,
You might enable the Collect Contacts Data checkbox from the Contacts entity and access this info through the Overlap grid function from the Contacts | Properties tab.Â
It shows the overlap length for each particle.
best regards,
Lucas
- The topic ‘Particle overlap’ is closed to new replies.
